[postgis-users] Finding polygons outside other polygons
Martin Weinelt
mweinelt at planiglobe.com
Mon Mar 8 00:38:47 PST 2010
Hello to all,
in a current project, I am trying to do a bit more serious stuff with PostGIS,
apart from using it as as a backend for web mapping.
I could use some tips or guidelines for the follwing - not very complicated -
task.
I have two tables, one holding some 3000 polygons describing city limits,
another with some 100000 polygons describing individual houses.
What I would like to have is another table with all houses outside any city
limits.
The following function seem to be candidates for this
ST_Disjoint
ST_Covers (not)
ST_Within (not)
ST_Intersects (not)
ST_Distance
First thing I did was to put the city polygons into one MultiPolygon (table
with one row, 'my_cities_multi' ). Then , for the sake of testing this, I
ran :
select count(a.the_geom) from my_houses as a , my_cities_multi as f
where ST_Disjoint( a.the_geom , f.the_geom )
This took some 30 minutes on a 3 GHz, two core machine and ended with:
"NOTICE: IllegalArgumentException: Points of LinearRing do not form a closed
linestring"
I've checked with ST_IsClosed on both tables, no complains.
I guess my task is a rather common application. But I am not that SQL-savvy.
May be some one can point me to a best practice with this, also in terms of
performance.
Thanks,
Martin
