[postgis-users] FW: Inserting value into geometry column error: Array value must start with "{" or dimension.
Majid Kazemi
Majid.Kazemi at teranet.ca
Wed Mar 10 09:18:10 PST 2010
Here is the DDL for Table creation:
CREATE TABLE gtest ( ID int4, NAME varchar(20) );
SELECT AddGeometryColumn('', 'gtest','geom',-1,'LINESTRING',2);
Thanks, Majid
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Kevin Neufeld
Sent: March 10, 2010 11:48 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] FW: Inserting value into geometry column
What's the DDL for your guest table?
On 3/10/2010 8:29 AM, Majid Kazemi wrote:
> *From:* Majid Kazemi
> *Sent:* March 10, 2010 11:02 AM
> *To:* 'postgis-users-bounces at postgis.refractions.net'
> *Subject:* Inserting value into geometry column error: Array value
> Hello all;
> Thanks for everyone help. I finally managed to install and configure
> Postgis.
> Now, I am trying to insert the following into a table with Geom
column.
> INSERT INTO guest(ID, NAME, GEOM)
> VALUES (1,'First Geometry',ST_GeomFromText('LINESTRING(2 3,4 5,6 5,7
> 8)', -1));
> I am receiving the following error:
> your help will highly be appreciated.
> Thanks, Majid
> postgis-users mailing list
