[postgis-users] FW: Inserting value into geometry column error: Array value must start with "{" or dimension.
Majid Kazemi Majid.Kazemi at teranet.ca
Wed Mar 10 10:07:53 PST 2010
 Thanks kevin;
It is working now.
I have to add "{"
INSERT INTO guest(ID, NAME, GEOM)
VALUES (1,'{First Geometry}',ST_GeomFromText('LINESTRING(2 3,4 5,6 5,7
8)', -1));
I have another question:
Any ideas how can I export Oracle spatial to Postgres (postgis)?
I saw there is a perl script called ora2pg.pl. Is there any other tools
available to perform this migration?
Thanks, Majid
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Kevin Neufeld
Sent: March 10, 2010 12:33 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] FW: Inserting value into geometry column
This is DDL for a table named "gtest", but you're inserting into a table
named "guest".  I suspect you're accidentally inserting into a different
table, one where the "GEOM" column is not of type "geometry".
In any case, your posted DDL is correct - so is this:
CREATE TABLE gtest (ID int4, NAME varchar(20), GEOM geometry);
Your insert statement then should work correctly:
INSERT INTO gtest(ID, NAME, GEOM)
VALUES (1,'First Geometry',ST_GeomFromText('LINESTRING(2 3,4 5,6 5,7
8)', -1));
Cheers,
Kevin
On 3/10/2010 9:18 AM, Majid Kazemi wrote:
>   Here is the DDL for Table creation:
> CREATE TABLE gtest ( ID int4, NAME varchar(20) ); SELECT
> AddGeometryColumn('', 'gtest','geom',-1,'LINESTRING',2);
> Thanks, Majid
> Kevin Neufeld
> Sent: March 10, 2010 11:48 AM
> What's the DDL for your guest table?
> On 3/10/2010 8:29 AM, Majid Kazemi wrote:
>> *From:* Majid Kazemi
>> *Sent:* March 10, 2010 11:02 AM
>> *To:* 'postgis-users-bounces at postgis.refractions.net'
>> *Subject:* Inserting value into geometry column error: Array value
>> Hello all;
>> Thanks for everyone help. I finally managed to install and configure
>> Postgis.
>> Now, I am trying to insert the following into a table with Geom
> column.
>> 8)', -1));
>> I am receiving the following error:
>> your help will highly be appreciated.
>> Thanks, Majid
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
