[postgis-users] FW: Inserting value into geometry column error:Array value must start with "{" or dimension.
Majid Kazemi
Majid.Kazemi at teranet.ca
Wed Mar 10 11:37:40 PST 2010
Thanks Paul.
I am looking for utility that help us to export table definitions and data from an Oracle spatial schema and import them into Postgres (Postgis) database.
Thanks, Majid
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
Sent: March 10, 2010 1:15 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] FW: Inserting value into geometry column error:Array value must start with "{" or dimension.
ogr2ogr
http://www.gdal.org/ogr2ogr.html
On Wed, Mar 10, 2010 at 10:07 AM, Majid Kazemi <Majid.Kazemi at teranet.ca> wrote:
> Thanks kevin;
> It is working now.
> I have to add "{"
> INSERT INTO guest(ID, NAME, GEOM)
> VALUES (1,'{First Geometry}',ST_GeomFromText('LINESTRING(2 3,4 5,6 5,7
> 8)', -1));
> I have another question:
> Any ideas how can I export Oracle spatial to Postgres (postgis)?
> I saw there is a perl script called ora2pg.pl. Is there any other
> tools available to perform this migration?
> Thanks, Majid
> Kevin Neufeld
> Sent: March 10, 2010 12:33 PM
> error: Array value must start with "{" or dimension.
> This is DDL for a table named "gtest", but you're inserting into a
> table named "guest". I suspect you're accidentally inserting into a
> different table, one where the "GEOM" column is not of type "geometry".
> In any case, your posted DDL is correct - so is this:
> CREATE TABLE gtest (ID int4, NAME varchar(20), GEOM geometry);
> Your insert statement then should work correctly:
> INSERT INTO gtest(ID, NAME, GEOM)
> VALUES (1,'First Geometry',ST_GeomFromText('LINESTRING(2 3,4 5,6 5,7
> 8)', -1));
> Cheers,
> Kevin
> On 3/10/2010 9:18 AM, Majid Kazemi wrote:
>> Here is the DDL for Table creation:
>> CREATE TABLE gtest ( ID int4, NAME varchar(20) ); SELECT
>> AddGeometryColumn('', 'gtest','geom',-1,'LINESTRING',2);
>> Thanks, Majid
>> Kevin Neufeld
>> Sent: March 10, 2010 11:48 AM
>> What's the DDL for your guest table?
>> On 3/10/2010 8:29 AM, Majid Kazemi wrote:
>>> *From:* Majid Kazemi
>>> *Sent:* March 10, 2010 11:02 AM
>>> *To:* 'postgis-users-bounces at postgis.refractions.net'
>>> *Subject:* Inserting value into geometry column error: Array value
>>> Hello all;
>>> Thanks for everyone help. I finally managed to install and configure
>>> Postgis.
>>> Now, I am trying to insert the following into a table with Geom
>> column.
>>> 8)', -1));
>>> I am receiving the following error:
>>> your help will highly be appreciated.
>>> Thanks, Majid
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
