[postgis-users] php/postgresql trouble
Nicklas Avén
nicklas.aven at jordogskog.no
Thu Mar 11 00:50:54 PST 2010
Hi
when you are using capitals in column name you have to use " around column name:
I am not good in php so I don't remember if it is ok to just double the " sign inside a string like
$sql = "INSERT INTO countries (""CountryID"", ""CountryName"", ""President"") VALUES .....
What I use to do is avoiding capitals in column names :-)
/Nicklas
2010-03-11 Linnet Kwamboka wrote:
hey guys,
>i dont know is anyone can help me i have been having trouble.
>i am using the follonwing code to do an INSERT query
> > if ($_POST['submit']) {
> // attempt a connection
> $dbh = pg_connect("host=localhost dbname=postgres user=postgres password=quash");
> if (!$dbh) {
> die("Error in connection: " . pg_last_error());
> else{
> echo "this was okay";
> //exit;
> // escape strings in input data
> // $code = pg_escape_string($_POST['code']);
>//$name = pg_escape_string($_POST['name']);
> //$president = pg_escape_string($_POST['president']);
> // execute query
> $sql = "INSERT INTO countries (CountryID, CountryName, President) VALUES('{$_POST['code']}', '{$_POST['name']}', '{$_POST['president']}')";
> $result = pg_query($dbh, $sql);
> if (!$result) {
> die("Error in SQL query: " . pg_last_error());
> echo "Data successfully inserted!";
> // free memory
> pg_free_result($result);
> // close connection
> pg_close($dbh);
> Country code:
> Country name:
> President's name:
>but i am getting the following error
> this was okay
>Warning: pg_query() [function.pg-query]: Query failed: ERROR: column "countryid" of relation "countries" does not exist LINE 1: INSERT INTO countries (CountryID, CountryName, President) VA... ^ in C:\xampp\htdocs\bongamate\weka.php on line 25
> Error in SQL query: ERROR: column "countryid" of relation "countries" does not exist LINE 1: INSERT INTO countries (CountryID, CountryName, President) VA... ^
>can anyone help me on this? thank you
> with regards geekmate!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100311/981487a7/attachment.html>
