[postgis-users] date/time format
Mike Toews
mwtoews at gmail.com
Sun Mar 14 15:54:02 PDT 2010
It depends on your database settings. You can see what it is from
either psql or PgAdmin:
show DateStyle;
(Mine shows "ISO, DMY")
If you want to temporary change it for an SQL session, try:
set DateStyle=SQL, DMY;
select current_timestamp;
And if you like it and want to make a global change for the database:
ALTER DATABASE mydb SET DateStyle=SQL, DMY;
More info:
http://www.postgresql.org/docs/current/static/datatype-datetime.html#DATATYPE-DATETIME-OUTPUT
-Mike
On 14 March 2010 10:27, Linnet Kwamboka <scientific1quash at gmail.com> wrote:
> hey guys,
> when making a table column with date, the date type is chosen, what is the
> exact date format that can be input? is it DMY or YMD and how can i change
> this format to be DMY for ease of use?thanks
> With regards,
> Linnet Kwamboka
> postgis-users mailing list
