[postgis-users] PostGIS with ArcGIS Desktop
Khurram Niaz Sheikh
khurram.niaz at tpltrakker.com
Mon Mar 15 05:39:08 PDT 2010
Arcgis data interoperability extension has support for postgis connection, did anyone had a try?
Regards,
Khuram
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ralf Suhr
Sent: Monday, March 15, 2010 2:54 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS with ArcGIS Desktop
Hello Wenbert,
ArcMap 9.x can not use PostGIS without overlaying ArcSDE.
Gr Ralf
Am Montag 15 März 2010 10:26:27 schrieb Wenbert Del Rosario:
> Hello,
> I am new comer to the GIS world. I hope you will be able to help me with my
> problem.
> But first, I have some questions:
> Will ArcMap work directly with PostGIS? If yes, what kind of data are
> stored in PostGIS?
> Will it store all my map files(mao file containing rasters, contours, etc)
> in the server? (No more editing local files? I am thinking of 1) Connect to
> database 2) load data in ArcMap/AutoCAD 3) Save data )
> Right now, my problem is that I have too many files on one machine. I want
> everything stored in a server so that when I travel, I can just login
> and retrieve/view my files. Is PostGIS the answer? Can anyone lead me to
> the right direction for a solution?
> Thank you very much.
> Sincerely,
> Wenbert
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
