[postgis-users] ERROR: array size exceeds the maximum allowed (134217727)
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Sat Mar 20 02:49:42 PDT 2010
Hello again,
It might be of interest to point out that substituting st_union() with
st_memunion() seems to have worked around this. I'm curious though, because
there is not a great deal of data being processed, and I am running this on a
fairly sturdy system that that has more capacity than some of the Fedora
systems I'm running.
Mike
On Saturday 20 March 2010 05:17:50 Mike Leahy wrote:
> Hello list,
> I have an interesting error that's coming up on an Ubuntu 64-bit system,
> running PostgreSQL 8.4.2, and PostGIS 1.5.1 (packaged by me) as well as
> 1.4.0 (from Ubuntu repos). The query itself is somewhat complex (I'm sure
> it could be optimized better - but it's been working well for quite some
> time). I've attached two files - one is a dummed-down version of the
> query I am running (crashing.sql). After discussing this with some folks
> in the postgresql IRC channel, it seems that the st_geom(), or something
> PostGIS-related is causing the error.
> Running this query on various data will produce one of two results. One is
> the error mentioned in the subject (ERROR: array size exceeds the maximum
> allowed (134217727)). I can find very little information on this error.
> The other outcome is that it often causes the PostgreSQL backend to
> segfault (see gdboutput.txt).
> I can attest that this query works fine on many installations of PostgreSQL
> 8.2+, and PostGIS 1.3+. The only main difference I can see in this case
> where I'm getting errors and segfaults is that I'm running this on Ubuntu,
> whereas all of my successful cases are on Fedora (7 through 12).
> If I replace the st_union() function in the query with accum(), it still
> produces the error/segfaults.
> Also, strangely, if I remove one of the where conditions near the end of
> the query (e.g., " AND (cl.depth = 0)"), it suddenly works fine without
> any issues (except that I actually need that condition).
> Does this sort of problem look familiar to anyone? I can try to put
> together an example if that would be of any use, but since the same
> data/query works on other Fedora systems that I am running, I'm not sure
> how easy it is to replicate.
> Regards,
> Mike
