[postgis-users] ERROR: array size exceeds the maximum allowed (134217727)
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Sat Mar 20 13:34:49 PDT 2010
Chris/list:
I have tried booting into the following kernels, all exhibiting the same
issue:
2.6.31-20-generic
2.6.31-19-generic
2.6.31-14-generic
I believe 2.6.31-14-generic is the original kernel installed with this version
of Ubuntu, so unless the change to the kernel you're thinking occurred
previous to the 9.10 Karmic release, it's not the culprit here.
Mike
On Saturday 20 March 2010 15:03:47 Mike Leahy wrote:
> Chris,
> Sorry for not catching this one sooner (I'm subscribed to the digest)...but
> thanks for pointing this out. The system is completely up to date. I could
> reboot into an older kernel to see if that solve the problem. I'll report
> results a bit later today.
> Mike
> Message: 7
> Date: Sat, 20 Mar 2010 10:03:13 -0700
> From: Chris Hermansen <chris.hermansen at timberline.ca>
> Subject: Re: [postgis-users] ERROR: array size exceeds the maximum
> allowed (134217727)
> To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> Message-ID: <4BA4FFD1.9020203 at timberline.ca>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Very recently there was a kernel patch in Ubuntu regarding - if memory
> serves - memory copying. How up to date is the system in question?
> strk wrote:
> > On Sat, Mar 20, 2010 at 07:56:14AM -0700, Paul Ramsey wrote:
> >> Actually, memunion does the opposite, it passes the resultant and
> >> preserves mem.
> > Oops, sorry for the confusion. Not-so-intuitive name :P
> > --strk;
> > () Free GIS & Flash consultant/developer
> > /\ http://strk.keybit.net/services.html
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
