[postgis-users] ERROR: array size exceeds themaximumallowed(134217727)
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Sun Mar 21 20:54:44 PDT 2010
Leo/Regina,
Yes, I can confirm that the non-working queries work when enable_nestloop is
off, and enable_hashjoin is on.
The opposite is not the case - setting enable_nestloop on and enable_hashjoin
off does not make the 'working' variations of my query crash.
Nice catch - is there anything further I can do from my end to troubleshoot
this?
Mike
On Sunday 21 March 2010 23:01:34 Paragon Corporation wrote:
> Mike and Paul,
> We took a quick look at the query plans. Admittedly we suck at reading
> text plans; always rely on the graphical explain.
> Anyrate -- one striking thing it seems between the ones that don't work and
> the ones that work are
> The ones that work never employ a nested loop scan
> Both the segfault one and the exceed max allowed employ nested loops. So
> maybe its the interaction between nested loops and hash agg causing the
> problem.
> Could you two try disabling nested loop scan and run the crashing ones.
> Also verify that the plan has indeed changed to not use nested loops.
> set enable_nestloop = off;
> set enable_hashjoin = on;
> run query
> --- If you can't disable nested loop, try disabling the hash_join to see if
> you can make the working queries crash
> set enable_hashjoin = off;
> set enable_nestloop = on;
> run query
> Leo and Regina
> http://www.postgis.us
> -----Original Message-----
> From: Mike Leahy [mailto:mgl.gis at gmail.com] On Behalf Of Mike Leahy
> Sent: Sunday, March 21, 2010 7:43 PM
> To: Paul Ramsey
> Cc: PostGIS Users Discussion; Paragon Corporation
> Subject: Re: [postgis-users] ERROR: array size exceeds
> Ok,
> I've attached the smallest version of this query I can make before the
> error goes away. It seems to be very particular, but at least I have been
> able to take out some of the subqueries. Does this still produce the error
> in your environments as well?
> Mike
> On Sunday 21 March 2010 18:28:59 Paul Ramsey wrote:
> > Suggests nothing in particular, I'm afraid, because this isn't my area
> > of expertise ;) It's probably an 8-hour bug, so it could be a while
> > before I can devote an entire day to tracking back into it. It would
> > be ideal to have a smaller query that does the same thing.
> > On Sun, Mar 21, 2010 at 12:58 PM, Mike Leahy
> > <mgleahy at alumni.uwaterloo.ca> wrote:
> > > Paul,
> > > Thanks for looking into it - at least I know it's not just me (for
> > > the array size limit at least).
> > > What does a cleanly trapped error like this suggest to you? If you
> > > try different variations on the where condition at the end of the
> > > statement, are you able to get a segfault?
> > > Mike
> > > On Sunday 21 March 2010 12:57:03 Paul Ramsey wrote:
> > >> As I was installing KUbuntu, I realized I should try the query on
> > >> my own system, and under OS/X 10.6 I see the array error, though it
> > >> seems to be cleanly trapped, there is no segfault.
> > >> crashdb=# \i ./crashing.sql
> > >> psql:./crashing.sql:36: ERROR: array size exceeds the maximum
> > >> allowed
> > >> (134217727)
> > >> crashdb=#
> > >> P.
> > >> On Sat, Mar 20, 2010 at 9:29 PM, Mike Leahy
> > > wrote:
> > >> > Leo/Regina,
> > >> > In response to your earlier message, I did find that report of
> > >> > the identical error message. However, as I'm sure you noticed,
> > >> > there is no apparent investigation that followed after it. That
> > >> > was why I went to the PostgreSQL IRC channel first...they walked
> > >> > me through generating a core dump, which is what then pointed to
> > >> > it being a problem related to PostGIS. So while it's certainly
> > >> > the same error being reported, the source of the problem in this
> > >> > case appears PostGIS-specific - likely due to the logic that you
> > >> > note was borrowed from the array_agg that caused the problem in the
> previous report.
> > >> > As for looking at the different query plans for
> > >> > working/non-working versions of the statement with different
> > >> > where conditions, I've attached several results in text files.
> > >> > Two examples that worked, one that segfaults, and one that produces
> the 'array size exceeds...'
> > >> > error message. All of these are the same query, just with
> > >> > variations in the where condition. The query plan is a but much
> > >> > for me to interpret though - what does this look like to the
> > >> > experts?
> > >> > Mike
> > >> > On Saturday 20 March 2010 23:35:32 Paragon Corporation wrote:
> > >> >> Mike,
> > >> >> Another thought. I suppose it could be the more or less two
> > >> >> identical subselects both with array_aggs Just to give Paul
> > >> >> something hopefully shorter to work with. Does this fail too?
> > >> >> SELECT csls.chat_id, csls.ugeom
> > >> >> FROM (
> > >> >> SELECT '[stuff]' AS selection, st_union(geom) AS ugeom,
> > >> >> csl1.chat_id FROM testdb.user_selections AS us1
> > >> >> INNER JOIN testdb.chat_selection_links AS csl1 ON us1.id =
> > >> >> csl1.selection_id
> > >> >> WHERE (not us1.user_drawing and not csl1.deleted)
> > >> >> GROUP BY chat_id
> > >> >> ) AS csls
> > >> >> LEFT JOIN (
> > >> >> SELECT '[stuff]' AS drawing, st_union(geom) AS ugeom,
> > >> >> csl2.chat_id FROM testdb.user_selections AS us2
> > >> >> INNER JOIN testdb.chat_selection_links AS csl2 ON us2.id =
> > >> >> csl2.selection_id
> > >> >> WHERE (us2.user_drawing and us2.deleted and not csl2.deleted)
> > >> >> GROUP BY chat_id
> > >> >> ) AS csld ON csls.chat_id = csld.chat_id
> > >> >> Leo and Regina,
> > >> >> From: postgis-users-bounces at postgis.refractions.net
> > >> >> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf
> > >> >> Of Paragon Corporation
> > >> >> Sent: Saturday, March 20, 2010 11:29 PM
> > >> >> To: 'PostGIS Users Discussion'; mgleahy at alumni.uwaterloo.ca
> > >> >> Mike,
> > >> >> Actually scanning thru the archives that 13... is a common
> > >> >> number so suspect that is an OS limit.
> > >> >> This could be very well a bug in PostgreSQL 8.4.
> > >> >> Have you tried this on other PostgreSQL 8.4 installs on other
> > >> >> your Fedoras - you mentioned trying on older installs?
> > >> >> Your problem sounds exactly like this guy's and he wasn't using
> > >> >> PostGIS at all but array_agg (which is logic that PostGIS
> > >> >> borrowed from to implement the faster collecting ST_Union
> > >> >> behavior)i
> > >> >> http://archives.postgresql.org/pgsql-hackers/2009-06/msg01171.ph
> > >> >> p
> > >> >> If you haven't already probably good to check the plan
> > >> >> difference between the two queries (one with addtional WHERE and
> > >> >> one
> without).
> > >> >> It could be doing something nuts like running the sub select
> > >> >> for each record you have in the outer only when your extra WHERE
> > >> >> condition is added and doing more or less the sane thing when
> > >> >> you take it out.
> > >> >> We've had some odd behavior in 8.4 with the planner doing
> > >> >> strange things that we haven't been able to pin down and had to
> > >> >> implement workaround for. As we described in this article.. Its
> > >> >> probably unrelated though but just a thought to throw out at the
> wind.
> > >> >>http://www.postgresonline.com/journal/index.php?/archives/149-For
> > >> >>cing -th e-p l anners-hand-with-set-enable_seqscan-off-WTF.html
> > >> >> Leo and Regina,
> > >> >> Of Paul Ramsey
> > >> >> Sent: Saturday, March 20, 2010 8:23 PM
> > >> >> To: mgleahy at alumni.uwaterloo.ca; PostGIS Users Discussion
> > >> >> Subject: Re: [postgis-users] ERROR: array size exceeds the
> > >> >> Mike
> > >> >> Well, if you can reduce it to a small db dump and query that
> > >> >> exercises it, I can install a 64bit ubuntu VM and see if it
> > >> >> happens here too.
> > >> >> P
> > >> >> On Sat, Mar 20, 2010 at 3:30 PM, Mike Leahy
> > >> >> wrote:
> > >> >> > FWIW, if I remove the entire where clause at the end of the
> > >> >> > statement, it works again (with st_union()) and is virtually
> > >> >> instantaneous.
> > >> >> > On Saturday 20 March 2010 18:10:38 Mike Leahy wrote:
> > >> >> >> Hey,
> > >> >> >> The query (when it works) is virtually instantaneous when I
> > >> >> >> use
> > >> >> >> st_memunion() (or when I took out part of the where clause -
> > >> >> >> although now I can't even get that to work, so maybe it was
> > >> >> >> just lucky). Each of the subqueries also work fine without
> > >> >> >> any obvious problem.
> > >> >> >> To me, it seems to be a combination of things that somehow
> > >> >> >> add up to this limitation...I don't see what settings could
> > >> >> >> affect the array size limit (in postgresql.conf). Can
> > >> >> >> anyone point to a config option that might make a
> > >> >> >> difference, or maybe point to another place with settings I
> > >> >> >> can tinker with?
> > >> >> >> Mike
> > >> >> >> On Saturday 20 March 2010 17:53:24 Paragon Corporation wrote:
> > >> >> >> > Mike,
> > >> >> >> > We apologize, didn't notice this was in a subquery and that
> > >> >> >> > you have a
> > >> >> >> > limit statement in your query. So we presume regardless of
> > >> >> >> > your WHERE
> > >> >> >> > only 26 records are being selected.
> > >> >> >> > So Paul could be right that you do have data that is
> > >> >> >> > hitting some compiled or variable limit.
> > >> >> >> > Does running the subquery alone work or you didn't try
> > >> >> >> > because it takes a long time?
> > >> >> >> > Thanks,
> > >> >> >> > Leo and Regina
> > >> >> >> > Mike Leahy Sent: Saturday, March 20, 2010 2:01 PM
> > >> >> >> > To: Paragon Corporation
> > >> >> >> > Cc: 'PostGIS Users Discussion'
> > >> >> >> > maximum allowed(134217727)
> > >> >> >> > Hi Leo/Regina,
> > >> >> >> > Thanks for the suggestion. I tried adding the clause 'not
> > >> >> >> > geom is
> > >> >> null'
> > >> >> >> > to the where statement in each of the two sub-queries that
> > >> >> >> > have the st_union(geom) functions are used, but it still
> segfaults.
> > >> >> >> > I also tried this on a fresh database with very little
> > >> >> >> > data, and it doesn't seem to cause problems. But I have
> > >> >> >> > two databases with live data where I can cause this. I
> > >> >> >> > have been able to pare one of these down to remove personal
> > >> >> >> > information and reduce unnecessary data, while still
> > >> >> >> > generating
> the crash with that
> > >> >> >> > query. Would someone be interested in a dump of this db? Of
> > >> >> >> > course, that someone would ideally be able to test this on
> > >> >> >> > a 64-bit (K)ubutnu system, in the hopes that the problem
> > >> >> >> > can be replicated.
> > >> >> >> > Mike
> > >> >> >> > On Saturday 20 March 2010 11:32:35 Paragon Corporation wrote:
> > >> >> >> > > Paul,
> > >> >> >> > > I doubt array size limit is the issue. He said when he
> > >> >> >> > > left the where condition out it worked. I would think it
> > >> >> >> > > would definitely blow up in that case.
> > >> >> >> > > Mike,
> > >> >> >> > > The issue from before was that array aggregate functions
> > >> >> >> > > did not handle NULLs correctly. 64-bit systems were more
> > >> >> >> > > likely to segfault or give strange Errros in this case.
> > >> >> >> > > To rule out that we still have some of these issues in
> > >> >> >> > > the code base, can you add a
> > >> >> >> > > geom IS NOT NULL
> > >> >> >> > > Condition to your WHERE filter. If that works, then the
> > >> >> >> > > NULL issue is probably still lurking somewhere.
> > >> >> >> > > Leo and Regina
> > >> >> >> > > Behalf Of Paul Ramsey
> > >> >> >> > > Sent: Saturday, March 20, 2010 10:56 AM
> > >> >> >> > > To: PostGIS Users Discussion; mgleahy at alumni.uwaterloo.ca
> > >> >> >> > > the maximum
> > >> >> >> > > allowed(134217727)
> > >> >> >> > > Actually, memunion does the opposite, it passes the
> > >> >> >> > > resultant and preserves mem. The default behavior is
> > >> >> >> > > fast-but-memory-hungry. And has been for some time,
> > >> >> >> > > though in different forms. There were some bugs in the
> > >> >> >> > > array handling code, but Mark CA killed most of them, so
> > >> >> >> > > the latest 1.5 and
> > >> >> >> > > 1.4 streams should be good. If it's possible that the
> > >> >> >> > > issue is one of array size, maybe Mike could find the
> > >> >> >> > > dial that controls that maximum, and turn it up and down
> > >> >> >> > > and see if it makes his
> > >> >> >> > problem go away/happen sooner.
> > >> >> >> > > P.
> > >> >> >> > > On Sat, Mar 20, 2010 at 7:41 AM, strk <strk at keybit.net>
> wrote:
> > >> >> >> > > > On Sat, Mar 20, 2010 at 05:49:42AM -0400, Mike Leahy wrote:
> > >> >> >> > > >> Hello again,
> > >> >> >> > > >> It might be of interest to point out that substituting
> > >> >> >> > > >> st_union() with
> > >> >> >> > > >> st_memunion() seems to have worked around this. I'm
> > >> >> >> > > >> curious though, because there is not a great deal of
> > >> >> >> > > >> data being processed, and I am running this on a
> > >> >> >> > > >> fairly sturdy system that that has more capacity than
> > >> >> >> > > >> some of the Fedora systems I'm
> > >> >> running.
> > >> >> >> > > > st_memunion builds a big array with all geometries in it..
> > >> >> >> > > > you were hitting a limit of the array type.
> > >> >> >> > > > st_union should behave better.
> > >> >> >> > > > --strk;
> > >> >> >> > > > () Free GIS & Flash consultant/developer
> > >> >> >> > > > /\ http://strk.keybit.net/services.html
> > >> >> >> > > > _______________________________________________
> > >> >> >> > > > postgis-users mailing list
> > >> >> >> > > >postgis-users at postgis.refractions.net
> > >> >> >> > > >http://postgis.refractions.net/mailman/listinfo/postgis-
> > >> >> >> > > >user
> > >> >> >> > > >s
> > >> >> >> > > http://postgis.refractions.net/mailman/listinfo/postgis-u
> > >> >> >> > > sers
> > >> >> > http://postgis.refractions.net/mailman/listinfo/postgis-users
