[postgis-users] Confused about st_snaptogrid and precision.
Paul moen
pmoen at offroadsoftware.com
Tue Mar 23 07:37:59 PDT 2010
On Mar 23, 2010, at 7:10 AM, strk wrote:
> On Tue, Mar 23, 2010 at 01:05:52PM +0100, strk wrote:
>> On Tue, Mar 23, 2010 at 06:57:41AM -0500, Paul Moen wrote:
>>> UPDATE the_control SET the_geom=st_snaptogrid(the_geom,.0000001);
>>> After setting the precision, shouldn't I be able to find the
>>> point, POINT(1881581.0894989 638200.5564884), at that precision,
>>> in the table by using
>>> SELECT * FROM the_control WHERE
>>> st_equals(st_geomfromewkt('POINT(1881581.0894989
>>> 638200.5564884)'),the_geom);
>> You are NOT snapping the return from st_geomfromewkt.
>> Try this:
>> SELECT * FROM the_control WHERE st_equals(
>> st_snaptogrid(st_geomfromewkt('POINT(1881581.08949
>> 89 638200.5564884)', .0000001)),the_geom);
Bottom line, when I store a geometry using
st_geomFromEWKT('POINT(1881581.089489 638200.5564884)'), is is not
actually storing a geometry with an X of 1881581.089489 and a Y of
638200.5564884. It is storing a geometry with an X = some number
that rounds to 1881581.089489 and a Y = some number that rounds to
638200.5564884.
> Also, note that if the geometries you're comparing do not
> have the same structure (number of points in the same place)
> snapping to the grid may have the unexpected result of making
> them different than they were.
> This is because snapToGrid doesn't add new vertices, but only
> snaps the existing ones.
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
> postgis-users mailing list
