[postgis-users] postgis-users Digest, Vol 93, Issue 13
Trine Louring Nielsen
TRNI at rudersdal.dk
Wed Mar 24 04:57:14 PDT 2010
Hej Helge
Du lovede mig at du vil sende noget beskrivende materiale om jeres indberetningssystem.
Vh trine
-----Oprindelig meddelelse-----
Fra: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] På vegne af postgis-users-request at postgis.refractions.net
Sendt: 13. marts 2010 21:00
Til: postgis-users at postgis.refractions.net
Emne: postgis-users Digest, Vol 93, Issue 13
Send postgis-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://postgis.refractions.net/mailman/listinfo/postgis-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
postgis-users-owner at postgis.refractions.net
When replying, please edit your Subject line so it is more specific than "Re: Contents of postgis-users digest..."
Today's Topics:
1. Re: "ERROR: could not access file "$libdir/postgis-1.5": No
such file or directory" (Gissur ??rhallsson)
Message: 1
Date: Sat, 13 Mar 2010 15:15:21 +0000
Subject: Re: [postgis-users] "ERROR: could not access file
"$libdir/postgis-1.5": No such file or directory"
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Message-ID:
<497c70db1003130715i13b46658i35c6f494e73d8ad3 at mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
Hi there
pramsey solved this for me on irc:
I had installed and then removed postgresql 8.3 via apt previously - but some of it was still hanging about, to wit:
[120310 16:52:30] <pramsey> the problem is you have a system pg_config in /usr/bin, but I imagine the postgresql you are running is the one from /usr/local/pgsql [120310 16:53:04] <pramsey> export PATH=/usr/local/pgsql/bin:$PATH and the reconfigure, rebuild, reinstall your postgis
This did the trick
Thanks anyway,
and kind regards from Iceland,
Gissur
On Fri, Mar 12, 2010 at 7:13 PM, Jorge Arevalo <jorgearevalo at gis4free.org>wrote:
> 2010/3/12 Gissur ??rhallsson <gissur at loftmyndir.is>:
> > Hi,
> > I'm setting up postgis on a Ubuntu 8.0.4 LTS Server that I'm setting up.
> > I decided that it would be best for me build Postgis 1.5 from source
> > so that's what I did - starting with Postgres 8.4.2 from trunk
> > through GEOS
> and
> > PROJ and everything went fine. I've now also compiled postgis 1.5
> > and was preparing to run new_postgis_restore.pl to restore my
> > database (migrated from windows postgresql 8.2).
> > When I try to run psql postgis.sql on the database I intend to
> > restore
> into
> > (as stipulated inside new_postgis_restore.pl) I get the
> > following: http://postgis.pastebin.com/TCC0yk35
> > Running $ldd /absolute/path/to/postgis-1.5.so returns
> > this: http://postgis.pastebin.com/yERz1HeY (which looks normal
> > enough)
> > For further reference I enclose my pg_config
> > output: http://postgis.pastebin.com/6u3zfTyc
> > LIBDIR is set to /usr/lib in there, and my postgis-1.5.so is located
> > at /usr/lib/postgresql/8.4/lib/ postgis-1.5.so Does anybody have
> > any ideas?
> > Kind regards from Iceland,
> > Gissur ??rhallsson
> > Loftmyndir ehf.
> > Laugavegur 13
> > IS 101 Reykjav?k - Iceland
> > s?mi (tel): (+354) 540 2500
> > t?lvup?stur (email): gissur at loftmyndir.is
> Hi,
> Try adding /usr/lib/postgresql/8.4/lib/postgis-1.5.so to
> /etc/ld.so.conf and then executing "sudo ldconfig"
> Hope this helps...
> Best regards,
> Jorge
Gissur ??rhallsson
Loftmyndir ehf.
Laugavegur 13
URL: <http://postgis.refractions.net/pipermail/postgis-users/attachments/20100313/c3bdf483/attachment-0001.html>
End of postgis-users Digest, Vol 93, Issue 13
