[postgis-users] Read file encoding from from shape file
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Thu Mar 25 10:18:20 PDT 2010
Well, I've started to compare the version in PostGIS with that from
shapelib, dated 2003-07-08 (that should be approx the date of the fork).
I've run indent on those files, so that diff produces less noise caused
by changing white spaces.
In the PostGIS version are:
 1) a lot of added casts to unsigned int
 2) some bug fixes, which I would be cautious to port, since the same
bugs may have been fixed in the main shapelib
 3) 2 new functions: DBFReadDeleted and DBFReadSetup. Here I'm not sure
what really happens here.
 4) support for date. This seems to be easy and I've posted the diffs to
the shapelib mailing list.
The diff between current PostGIS version and those of Shapefile dated
2003-07-08 are attached.
Regards,
Peter
Paul Ramsey wrote:
> Yes, there's patches to our shapelib that don't exist in the mainline.
> The process needs to identify our changes to feed back to mainline,
> update mainline, then bring that in.
> P.
> On Sat, Mar 20, 2010 at 3:41 PM, Peter Hopfgartner
> <peter.hopfgartner at r3-gis.com> wrote:
>> Paul Ramsey wrote:
>>> I was never certain that ESRI software actually respected the DBF code
>>> page flags, but your reference indicates they do, so this seems
>>> reasonable. Some investigation of the current state of shapelib WRT
>>> encoding would be wise, as I think we should update our shapelib to
>>> the current version when we release 2.0.
>>> P.
>> I had a look if it was quick deal to upgrade to current shapelib. I copied
>> dbfopen.c, shpopen.c and shapefil.h from a currrent the shapelib checkout.
>> Unfortunatly, it seems to me that date handling has disappeared from
>> shapelib. At least FTDate is not defined anymore and in DBFOpen no 'D' is
>> assigned as field type.
>> Am I missing something obvious here?
>> Regards,
>> Peter
>>> On Fri, Feb 26, 2010 at 5:55 AM, Peter Hopfgartner
>>>> Hi
>>>> Looking into the sources of shp2pgsql, [0], it seems that the loader
>>>> assumes
>>>> that the encoding of the dbf file is  "WINDOWS-1252", if not specified
>>>> differently by the -W command line option.
>>>> From [1], shape files carry some information about their encoding, either
>>>> in
>>>> the dbf file header at byte position 29, [2], or in a separate file with
>>>> extension CPG.
>>>> Would it make sense to change the default behaviour of shp2pgsql into:
>>>> 1) try to get file encoding from dbf file or cpg file
>>>> 2) if 1) fails, take WINDOWS-1252 as default
>>>> 3) if -W is given, take this option
>>>> And then, is the information about the encoding set by pgsql2shp? It
>>>> would
>>>> be smooth, if shapes generated by pgsql2shp could be imported by
>>>> shp2pgsql
>>>> without specifying any encoding during import ("just works").
>>>> Regards,
>>>> Peter
>>>> [0] http://trac.osgeo.org/postgis/browser/trunk/loader/
>>>> [1]
>>>> http://support.esri.com/index.cfm?fa=knowledgebase.techArticles.articleShow&d=21106
>>>> [2] http://www.dbase.com/knowledgebase/int/db7_file_fmt.htm
>>>> Dott. Peter Hopfgartner
>>>> R3 GIS Srl - GmbH
>>>> Via Johann Kravogl-Str. 2
>>>> I-39012 Meran/Merano (BZ)
>>>> Email: peter.hopfgartner at r3-gis.com
>>>> Tel. : +39 0473 494949
>>>> Fax  : +39 0473 069902
>>>> www  : http://www.r3-gis.com
>>>> XING : http://www.xing.com/go/invita/8917535
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> R3 GIS Srl - GmbH
R3 GIS Srl - GmbH
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100325/69b19944/attachment.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100325/69b19944/attachment-0001.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100325/69b19944/attachment-0002.bin>
