[postgis-users] transformation discrepancy with postgis v. cs2cs
Paul Ramsey
pramsey at opengeo.org
Thu Mar 25 12:55:24 PDT 2010
It's probably a function of your installation, I get the same results
as cs2cs on my PostGIS;
postgis15=# select astext(transform(setsrid(makepoint(1234488,
744181), 32003), 32100));
astext
POINT(366704.349230461 199132.534090009)
(1 row)
If the grid shift files are missing or not being found by postgis for
some reason (which could be a host of reasons depending on how you
compiled / installed proj) then you'd get a different result.
P
On Thu, Mar 25, 2010 at 8:55 AM, Bryan Keith <bryan at ideotrope.org> wrote:
> Hello,
> I'm not sure if this is the correct list for this question, but here goes.
> If I ought to post to another list, please let me know which one.
> I'm seeing a discrepancy between coordinate transformations in postgis and
> transformations using cs2cs with the exact same proj.4 string. Here are
> the proj.4 strings and transformation using postgis:
> select proj4text from spatial_ref_sys where srid = 32003;
> proj4text
> +proj=lcc +lat_1=46.4 +lat_2=44.86666666666667 +lat_0=44 +lon_0=-109.5
> +x_0=609601.2192024384 +y_0=0 +ellps=clrk66 +datum=NAD27
> +to_meter=0.3048006096012192 +no_defs
> (1 row)
> select proj4text from spatial_ref_sys where srid = 32100;
> proj4text
> +proj=lcc +lat_1=49 +lat_2=45 +lat_0=44.25 +lon_0=-109.5 +x_0=600000
> +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs
> (1 row)
> select astext(transform(setsrid(makepoint(1234488, 744181), 32003), 32100));
> astext
> POINT(366770.791392722 199138.151643548)
> Here is the transformation using cs2cs:
> cs2cs +proj=lcc +lat_1=46.4 +lat_2=44.86666666666667 +lat_0=44
> +lon_0=-109.5 +x_0=609601.2192024384 +y_0=0 +ellps=clrk66 +datum=NAD27
> +to_meter=0.3048006096012192 +no_defs +to +proj=lcc +lat_1=49 +lat_2=45
> +lat_0=44.25 +lon_0=-109.5 +x_0=600000 +y_0=0 +ellps=GRS80 +datum=NAD83
> +units=m +no_defs
> 1234488 744181
> 366704.35 199132.53 0.00
> Why the discrepancy? I'm guessing it has something to do with how datum
> shifts are handled. So which one is right? That's probably going to
> depend on something that I don't know about my input data, but maybe
> someone will enlighten differently. Thank you.
> Bryan
> postgis-users mailing list
