[postgis-users] PSQL command to drop table from a databae
Kevin Neufeld
kneufeld at refractions.net
Sun Mar 28 09:25:12 PDT 2010
Since you are using a non-standard way of naming your table (starting
with number), as Oliver was explaining, you need to double quote your
table name.
$ set mytab=\"123foo\"
$ echo $mytab
"foo"
$ psql -c "CREATE TABLE $mytab( a int ) " postgis
CREATE TABLE
$ psql -c "\dt" postgis
List of relations
Schema | Name | Type | Owner
public | 123foo | table | kneufeld
public | geometry_columns | table | kneufeld
public | spatial_ref_sys | table | kneufeld
(3 rows)
$ psql -c "DROP TABLE $mytab" postgis
DROP TABLE
-- Kevin
On 3/28/2010 8:35 AM, Shreerang Patwardhan wrote:
> Hi Ollvier,
> I was just writing to you about your previous mail. Well, th e DROP
> TABLE command is not working at my end. I have used double quotes
> also. Can you guess what could the problem be? I am trying to use that
> command in a shell script and it is not working. I have also tried it
> on the terminal and still the result is the same....ERROR!!!.....
> Need help!!!
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100328/8a173914/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100328/8a173914/attachment.png>
