[postgis-users] Polygon validity
Andrea Peri
aperi2007 at gmail.com
Tue Mar 30 23:46:16 PDT 2010
>Thanks a lot for taking you time to explain.
>So if Postgis actually not limit only to the simple-feature model the
>ST_IsValid,
>what kinds of geometries are InValid in PostGIS terms?
>So does this make my example non-compliant with OGC SFA? I'm not
>topology expert and asking for the practical reasons, the software
>that claims to be OGC-compliant cannot import such data correctly. If
>such structures are indeed not covered by OGC SFA then I cannot do
>anything, if they are allowed, than this is a software issue and it is
>in fact not compliant.
You can use the ST_IsSimple to know if a geometry is simple-feature.
If true it is simple-feature.
After, if you geometry is ST_IsSimpe = true,
you can test with ST_IsValid , to detect eventually invalidity for geometry.
So you can detect if it is a simple-feature valid geometry.
Andrea.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100331/c9859106/attachment.html>
