[postgis-users] Nested loop join = very bad performance
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Wed Mar 31 13:13:35 PDT 2010
Thanks again for the suggestions. The default values for join_collapse_limit
and from_collapse_limit were set to 8 - I upped these both to 128, with no
observable difference.
I guess this issue is better suited for the general PostgreSQL mailing
lists...
Regards,
Mike
On Wednesday 31 March 2010 15:51:14 Paragon Corporation wrote:
> Mike,
> Couple of thoughts. Given you have so many joins, could be you are
> reaching the join collapse limit and the planner is kicking out before
> making an optimal plan.
> Try increasing the join_collapse_limit and from_collapse_limit
> As was detailed in this thread
> http://archives.postgresql.org/pgsql-performance/2009-04/msg00258.php
> Alternatively could be your actual and estimated costs are out of wack and
> might help upping your default targets and reanalyzing data. You can
> probably get a sense of this by doing a an explain analyze of your query
> and comparing the actual cost/row count with the estimated cost/row count
> where its doing a nested loop.
> Admittedly this hasn't helped much for us.
> http://archives.postgresql.org/pgsql-performance/2009-02/msg00336.php
> Leo and Regina,
> http:///www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Mike
> Leahy
> Sent: Wednesday, March 31, 2010 1:17 PM
> To: Mark Cave-Ayland
> Cc: PostGIS Users Discussion
> Subject: Re: [postgis-users] Nested loop join = very bad performance
> Hi Mark,
> I set effective_cache_size to 3072mb, and shared_buffers to 1024mb (as my
> system has a total of 4gb). This only slightly (if at all) improves the
> performance, maybe reducing the query by somewhere around 500 ms (down to
> ~14700 ms). All other parameters in the postgresql.conf are defaults. I
> don't recall exactly what I changed before (I was just tried increasing
> memory limits and other things pretty much without knowing what I was
> doing), but none of that really seems to have a significant impact on the
> performance.
> The challenge with trying to reduce this query is that the nested loop join
> only happens with the query as a whole (in general). The briefest example
> I could put together was presented in the thread last week (see the
> attachment here:
> http://postgis.org/pipermail/postgis-users/2010-March/026239.html). If I
> pull any more parameters or parts out of the query, the nest loop (and the
> resulting errors/crashes I was encountering at the time) would not happen.
> Regards,
> Mike
> On Wednesday 31 March 2010 04:40:09 Mark Cave-Ayland wrote:
> > Mike Leahy wrote:
> > > Mark/List,
> > > I just replaced my postgresql.conf with the default copy that
> > > appears in /etc/postgresql/8.4/main/ after a fresh install. The
> > > performance is pretty much the same as before (maybe even about 400
> > > ms worse than before).
> > > Is there anything else I should try?
> > > Mike
> > Hi Mike,
> > Which parameters did you change? effective_cache_size and
> > shared_buffers should be tweaked to suit the RAM available in your
> > machine but the rest of the defaults are fairly sensible.
> > You probably want to set effective_cache_size to ~75% of your physical
> > RAM and shared_buffers to ~25%. Does that make any difference at all?
> > Otherwise, you'll need to start breaking down your query into parts to
> > see which bit is causing the slowdown. Start with the innermost query
> > and then add one join at a time until you find the part which is
> > ATB,
> > Mark.
> postgis-users mailing list
