[postgis-users] Converting UTM to lat/lon using Postgis
Francis Markham
fmarkham at gmail.com
Mon May 3 01:22:58 PDT 2010
Try http://www.spatialreference.org/ref/esri/3997/postgis/ The site is down
for me at the moment but should have the goods.
-Francis
On 3 May 2010 17:50, Mehmet Erkek <merkek at reidin.com> wrote:
> Thank you for the fast answer!
> Hmm. It looks I don’t have srid 3997 in the DB.
> =# select srid, srtext, proj4text from spatial_ref_sys where srid=3997;
> srid | srtext | proj4text
> (0 rows)
> select srid, srtext, proj4text from spatial_ref_sys where srtext like
> '%Dubai%';
> (0 rows)
> Could this be related to my postgis installation?
> I don’t see this srid in spatial_ref_sys.sql which came with postgis
> installation either.
> Any idea how I can fix this?
> *Mehmet ERKEK***
> www.REIDIN.com <http://www.reidin.com/>
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *Francis
> Markham
> *Sent:* Monday, May 03, 2010 11:09 AM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Converting UTM to lat/lon using Postgis
> Hi Mehmet,
> When you imported the shapefile, the SRID you are meant to specify is the
> SRID of the data, not the SRID you want. Since the data is in Dubai Local
> TM, the SRID is 3997. To get the transformation you want, try the
> following:
> select ST_AsText( ST_Transform(centroid(ST_SetSRID(the_geom,
> 3997)),4326)) from ult.test2 limit 5;
> Hope that helps,
> -Francis
> On 3 May 2010 17:03, Mehmet Erkek <merkek at reidin.com> wrote:
> Hi All,
> I havea a shape file which I imported it to a table called ‘test2’ (using
> SRID=4326). I want to get centroids of geometries in lat/lon.
> Here is what I run:
> select ST_AsText( ST_Transform(centroid(the_geom),4326)) from ult.test2
> limit 5;
> and what I get:
> POINT(496597.996430787 2774798.21242881)
> POINT(496332.629887436 2793339.61534586)
> POINT(496302.627327975 2793317.82477318)
> POINT(496305.255261594 2793353.29646291)
> POINT(496241.538851096 2774826.65593589)
> So far all is fine except coordinates which are not latitude/longitude
> *My question is : How can I convert/get these coordinates in lat/lon?*
> This what I have in my prj file:
> PROJCS["Dubai Local Transverse Mercator
> (DLTM)",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",55.33333333333334],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
> And this is my postgis version: POSTGIS="1.3.6" GEOS="2.2.3-CAPI-1.1.1"
> PROJ="Rel. 4.7.1, 23 September 2009" USE_STATS
> I appreciate any help. Thank you.
> *Mehmet ERKEK*
> This message is for the designated recipient only and may contain
> privileged, proprietary, or otherwise private information. If you have
> received it in error, please notify the sender immediately and delete the
> original. Any other use of the email by you is prohibited. Please Consider
> the Environment Before Printing This Email
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100503/7fc901ab/attachment.html>
