[postgis-users] ShootingStar: Rule with comma separated... bug?
Fred Lehodey
lehodey at gmail.com
Tue May 4 02:42:20 PDT 2010
Hi Maria.
If you need multiple restrictions for a given edge then you have to add
multiple records for that edge each with a separate restriction
http://pgrouting.postlbs.org/wiki/ShootingStar
Fred.
On Tue, May 4, 2010 at 10:14 AM, Maria Arias de Reyna <marias at emergya.es>wrote:
> Hi,
> I'm trying to do a shooting_star calculation following this example:
> http://www.davidgis.fr/blog/index.php?2008/07/24/349-shooting-star-usage-example-with-turn-restriction
> But I think that it has a bug when reading the rule. If I try to set more
> than
> one restriction on a rule, like
> update routing set to_cost = 1000000,rule='9,5' where id = 6;
> it only works for the first edge defined on rule (9), not the second edge
> (5).
> Am I doing something wrong or is it a bug?
> If I invert the rule:
> update routing set to_cost = 1000000,rule='5,9' where id = 6;
> it works well for the first edge again (5), but not for the second (9).
> María Arias de Reyna Domínguez
> Área de Operaciones
> Emergya Consultoría
> Tfno: +34 954 51 75 77 / +34 607 43 74 27
> Fax: +34 954 51 64 73
> www.emergya.es
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100504/da78faae/attachment.html>
