[postgis-users] OSM2pgsql, OpenStreetMap, MapServer, EPSG:900913, OpenLayers: issue
roshni.spain
roshni.aruna at gmail.com
Thu May 6 06:10:12 PDT 2010
Hi, I have more or less the same problem than you. I am rendering OSM data
(imported to PostGIS with osm2pgsql) and i need to view the map with
OpenLayers on MapServer.
I am more or less on the same point than you, because when i changed on the
map file all the projection info to "init=epsg:900913", the map goes blank.
It comes empty with no information. Plus, the mapserver does not return any
error in the log, and i really have no clue what i can do to fix this.
My OSM data table (planet_osm_line) is on epsg:900913 and this is what i
need to show on the map, but with no success. I have tried many options but
i can never go further than this.
Any clue??
Thank you
ibrahim saricicek wrote:
> Hi;
> 1) is your osm data table in Epsg:4326 projection?
> if so use; "init=epsg:4326" for each layer..
> 2) 'grey empty image'?? so you can get map from mapserver?
> right click on a tile and copy image location. Try the copied url, is
> there
> an error?
> Regards..
> On Tue, Mar 16, 2010 at 12:20 PM, Mulone1 <mulone at rome.com> wrote:
>> (apologies for cross-posting)
>> Hi everybody,
>> I'm trying to render openstreetmap data on a WMS on MapServer.
>> The system used to work with epsg:4326 but in our project we need a
>> GoogleMaps like projection and we chose epsg:900913.
>> These are the steps I followed to reimport everything for the new
>> projection:
>> 1) download osm xml file from Cloudmade (e.g. Italy.osm.bz2)
>> 2) Run 900913.sql on my PostGIS
>> 3) import that file into PostGIS with command:
>> ./osm2pgsql -U userid -W -H host -d maps -p myprefix -S default.style -c
>> -m
>> italy.osm.bz2
>> 4) At this point everything seems ok. The geometry columns have 900913 as
>> SRID.
>> 5) update MapFile with:
>> WEB
>> METADATA
>> wms_srs "epsg:900913"
>> PROJECTION
>> "init=epsg:900913"
>> END
>> Then in each layer I put:
>> PROJECTION "init=epsg:900913" END
>> and all of the queries have: using srid=900913
>> 6) load the wms layer into OpenLayers
>> with
>> var wms = new OpenLayers.Layer.WMS("OpenStreetMap", mainurl, {
>> units : 'm',
>> projection:new OpenLayers.Projection("EPSG:900913"),
>> Unfortunately all I get is a grey empty image. Looking at the map server
>> log
>> I noticed that it's full of:
>> [Mon Mar 15 17:49:44 2010].517000 msPostGISLayerWhichShapes query status:
>> 2
>> [Mon Mar 15 17:49:44 2010].517000 msPostGISLayerWhichShapes got 0 records
>> in
>> result.
>> [Mon Mar 15 17:49:44 2010].517000 msPostGISLayerNextShape called.
>> With the other projection I was getting the records.
>> Do you have any idea about what could be wrong in my set up? I tried to
>> debug it in several ways but I couldn't find anything wrong.
>> Cheers,
>> Mulone
>> View this message in context:
>> http://old.nabble.com/OSM2pgsql%2C-OpenStreetMap%2C-MapServer%2C-EPSG%3A900913%2C-OpenLayers%3A-issue-tp27915684p27915684.html
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
View this message in context: http://old.nabble.com/OSM2pgsql%2C-OpenStreetMap%2C-MapServer%2C-EPSG%3A900913%2C-OpenLayers%3A-issue-tp27915684p28472339.html
