[postgis-users] Dot Density idea
David Fawcett david.fawcett at gmail.com
Thu May 6 11:33:48 PDT 2010
Doesn't OpenSource suck!!!
On Mon, May 3, 2010 at 11:49 PM, John Abraham <jabraham at ucalgary.ca> wrote:
> One of the things I miss about using ESRI's GIS is the ability to do dot-density maps.  Within a polygon, the number of dots is
An then an hour later...
http://lin-ear-th-inking.blogspot.com/2010/05/random-points-in-polygon-in-jts.html
Sure, it's not a PostGIS solution and isn't exactly there yet, but not bad...
Imagine the converse:
Dear Jack,
There is this useful feature that is missing from your software, when
do you think that you could get it into a release?...
