[postgis-users] Extract points from multipoint geometries
Charles Galpin
cgalpin at lhsw.com
Mon May 10 11:14:00 PDT 2010
Thanks Maxime!
On May 10, 2010, at 11:47 AM, Maxime van Noppen wrote:
> On 05/10/2010 05:32 PM, Charles Galpin wrote:
>> I searched the archives and saw this asked in 2005 but it didn't appear to have a resolution then. I have two points in a multipoint geometry which represent the start and end point of road segments that I need to extract the points back out of, but ST_PointN doesn't work for multipoints, nor can I convert the multipoint to a linestring with ST_MakeLine and use ST_PointN then on the resultant line (because it doesn't work on multipoint geometries either).
>> Does anyone know a way to do this?
> Hi,
> You can use the ST_Dump function.
> http://postgis.refractions.net/docs/ST_Dump.html
> Maxime
