[postgis-users] Problem with probe_geometry_columns()
Fred Lehodey
lehodey at gmail.com
Wed May 19 01:28:22 PDT 2010
Thanks Mark and Ben,
I will try to understand better what happens here.
Fred.
On Wed, May 19, 2010 at 4:31 AM, Ben Madin
<lists at remoteinformation.com.au>wrote:
> Fred,
> On 18/05/2010, at 22:38 , Fred Lehodey wrote:
> > I have no success trying the function probe_geometry_columns() with
> Postgis 1.5.0
> > 1) Not sure but comparing the SQL with Postgis 1.3.3:
> > the clause (in the INSERT step and not the count of probed)
> > "sridcheck.consrc LIKE '(srid('||a.attname||') = %)' in postgis 1.3.3
> > is now:
> > "sridcheck.consrc LIKE '(st_srid('||a.attname||') = %)' in postgis 1.5.0
> > This looks like a tipo error. (this is not the function here but the
> constraint text in pg_constraint)
> I think the st_ prefix is now required,
> > 2) I have a second problem with pg_constraint table and the "consrc"
> field.
> > Most of time I have something like :
> > "(public.srid(the_geom) = 27492)"
> > and not (as expected by the function probe_geometry_columns()) :
> > "(srid(the_geom) = 27492)"
> This was previously an issue if you installed postgis into other than the
> public schema. The public schema reference was in a few locations, so you
> need to search it out in the function defs and remove it and recreate the
> function if you don't want to upgrade.
> I have upgraded a number of databases to 1.5 from 1.4 and it seems to have
> fixed it... but I have also mucked it by not changing the search_path prior
> to running the upgrade, leaving me with multiple postgis function
> definitions!
> cheers
> Ben
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100519/52999406/attachment.html>
