[postgis-users] Problem with ST_ExteriorRing and ST_contains
didier peeters
dpeeter1 at ulb.ac.be
Thu May 20 06:21:01 PDT 2010
Finally the ST_Buffer(geom, 0.0) solution has worked fine when applied to the input polygons.
Didier
Le 20 mai 2010 à 12:14, didier peeters a écrit :
> Hello Nicolas,
> Thanks for this quick and useful answer.
> When I run the ST_IsValidReason on the rings it surprisingly doesn't find any error but when I run it on the original polygon layer I get errors like "Ring Self-intersection[-2.14772 42.5812]" which is what I expected.
> So I will try to find a solution on the mailing list history or maybe find a workaround.
> Didier
> Le 19 mai 2010 à 10:51, Nicolas Ribot a écrit :
>>> Hi everybody,
>>> I'm a postgis new user and I would like to submit here a problem I encounter. Here's what I do :
>>> from a polygon layer I merge some of them (with ST_UNION) into bigger ones according to an attribute value, then I make an exterior ring (with ST_Collect(ST_ExteriorRing())) around these and then I fill these rings (with ST_Contains) with all the original polygon that are inside ( I do this to have a coherent area without the holes I would have otherwise because of some data particularities).
>>> All this works very fine for 99.9 % of the polygons but fails on filling the rings for a few of them. When I look at these I see that they have a loop which is a probably due to a wrong geometry in the original polygons.
>>> Does any of you know how to deal with this ?
>>> Thanks for your help
>> Hi,
>> You should first check the geometry validity (st_isvalid,
>> st_isValidReason) and isolate invalid geometries to correct them
>> Some "tricks" can correct them automagically (st_buffer(geom, 0.0) for
>> instance) and some programs can help you identifiy invalid geometries
>> (Jump for instance, with its validation plugin).
>> Mailing list contains useful hints on how to correct invalid geometries.
>> HTH
>> Nicolas
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
