[postgis-users] ST_DWithin with radius 0.000001
nguyen liem liemnguyendl at gmail.com
Tue May 25 01:53:12 PDT 2010
Hi Nicklas
my dataset about 100.000 rows and after run my query i get about 15.000
rows. I has created index for "geom" field but it was improve the
perofrmance for ST_intersect
I used SRID 4326, but I don't know how to convert from degree to meter.
Cheers
On Tue, May 25, 2010 at 3:43 PM, Nicklas Avén <nicklas.aven at jordogskog.no>wrote:
> Ok
> The distance of 0.00001 degree in east west direction will vary depending
> on how far from the equator you are.
> How many points is there in your dataset?
> Do you see if the index is used?
> /Nicklas
> 2010-05-25 nguyen liem wrote:
> Hi Nicklas
> >Actually the points can be outside the polygon and returning true but it
> can be tolerance about 1 meters outside.
> >I'm using SRID: 4326. I would like to know 0.00001 with the projection
> 4326 is equal 1 meter or not ?
> >I used ST_Intersects (geom, geometry); but it's really slow, I don't know
> why.
> >I also used ST_Dwithin (geom, geometry, 0) and the result is empty, i
> couldn't found any neighbour.
> >Cheers
> On Tue, May 25, 2010 at 3:22 PM, Nicklas Avén <nicklas.aven at jordogskog.no>
> wrote:
> Hallo
> > What you are doing with ST_Dwithin is to check if your geom and geometry
> have parts closer to (or exactly) 0.00001 mapunits from eachother. If you
> are using a meter based SRID then you are checking if they are within
> 0.00001 meters from eachother. So actually in this case your points can be
> just outside the polygon and returning true. If you want to use st_dwithin
> you should use 0 instead of 0.00001 . But I don't think that is any faster
> than ST_Intersects. The important thing in both cases is to have working
> spatial indexes.
> > put an index on geom column in my_neighbour table and analyze the table.
> > Create index idx_mn_geom
> > on my_neighbour
> > using gist(geom);
> > analyse my_neighbour;
> > Then try:>
> > SELECT id, geom
> > FROM my_neighbour
> WHERE ST_Intersects (geom, geometry);
> > I guess that is the best solution.
> > Hope that helps
> > Nicklas>
> > Hi all
> > >At the first time i used ST_Contains but it take a long time, so I used
> ST_Dwithin to improve the performance for the query statement but i don't
> know it is correct or not.
> > >I would like to know my points are within in polygon or not:
> > >SELECT id, geom
> > >FROM my_neighbour
> > >WHERE ST_Dwithin (geom, geometry, 0.00001)
> > >geometry: is a polygon(input parameter).
> > >0.00001: I means the radius of geometry is 1 meters, is it right?
> > >Cheers.
> > >Liem Nguyen
> > >Developer
> > >Axon Active Corp.
> > >Direct Line      : +84 38 948 4645
> > >Fax                  : +84 38 811 3489
> > > Mobile Phone  : +84 168 994 8897
> > >Skype ID         : liemnguyendl2204
> > >Email               : liem.nguyen at axonactive.net /
> > Web Site          : axonactive.vn>
> > >Address           : 87 Thang Long Street,Gate 2 Ward 4,
> > >                          Tan Binh District, HCM city, Vietnam.
> >_______________________________________________
> > postgis-users mailing list
> >postgis-users at postgis.refractions.net
> >postgis.refractions.net/mailman/listinfo/postgis-users
> >Liem Nguyen
> >Developer
> >Axon Active Corp.
> >Email               : liem.nguyen at axonactive.net / liemnguyendl at gmail.com
Liem Nguyen
Developer
Axon Active Corp.
Web Site          : http://axonactive.vn
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100525/0ec760e6/attachment.html>
