[postgis-users] PostGIS: make check works, but I can't manually create a spatial database
Devrim GÜNDÜZ devrim at gunduz.org
Wed May 26 04:20:38 PDT 2010
On Wed, 2010-05-26 at 12:16 +0100, Peter Cotroneo wrote:
> When I try to create a spatial database (e.g., psql -d geodb -f
> postgis.sql), however, it doesn't work.  I get numerous errors that
> look as follows:
> psql:postgis.sql:7739: ERROR:  current transaction is aborted,
> commands ignored until end of transaction block
There should be something different before this. Could you please paste
it?
BTW, did you load plpgsql before running postgis.sql script?
Devrim GÜNDÜZ
PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
PostgreSQL RPM Repository: http://yum.pgrpms.org
Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org  Twitter: http://twitter.com/devrimgunduz
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20100526/0de12c26/attachment.pgp>
