[postgis-users] ST_AsBinary
Kevin Neufeld
kneufeld at refractions.net
Mon Nov 1 11:42:57 PDT 2010
Nice rendering decoration Michael ... I didn't know that was in OJ.
Or if you want, here's a simple plugin I use with OJ that exposes
jfreechart for displaying the 3rd ordinate. There's little in terms of
code comments as it was just a quick hack that I found very useful to
display the side profile of a river dataset I once worked on. Just drop
the jar along with jfree:jfreechart-1.0.13.jar and it's dependency,
jfree:jcommon-1.0.15.jar, in the OJ extension directory. CTRL-Z
activates the plot on a selected feature.
Cheers,
Kevin
On 10/31/2010 10:10 AM, Michaël Michaud wrote:
> Hi,
> There is not much functions in OpenJUMP to use Z ordinates, but you
> can render them with the following decorations styles :
> - Z vertex
> - Segment downhill ...
> Regards,
> Michaël
> Le 31/10/2010 17:53, Paragon Corporation a écrit :
>> Mike,
>> Thanks for the tip. Is there any way to render the Z coordinates
>> aside from the info panel. We don't have too many 3 D examples in
>> the book (and much of the book is already finalized), but in the
>> PostGIS Raster chapter we are in the middle of rewriting we do have
>> an example that converts a 2-D linestring into a 3 D linestring by
>> intersecting with Raster elevation data. Would be nice to have a 3D
>> representation of it.
>> Thanks,
>> Leo and Regina
>> http://www.postgis.us
>> *From:* postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
>> *Michaël Michaud
>> *Sent:* Sunday, October 31, 2010 11:52 AM
>> *To:* PostGIS Users Discussion
>> *Subject:* Re: [postgis-users] ST_AsBinary
>> Hi,
>> Thanks for the link. Very interesting faq indeed.
>> If you think it can be useful for the faq or for your book, I suggest
>> to add examples using As_EWKB instead of As_Binary to get data from
>> PostGIS with OpenJUMP as it seems to be the way to go not to loose z
>> ordinates.
>> Michaël
>> Le 31/10/2010 04:03, Paragon Corporation a écrit :
>>> Correct. In fact we even has this as our #1 FAQ for 1.5
>>> http://www.postgis.org/documentation/manual-1.5SVN/ch03.html#id2872420
>>> Thanks,
>>> Regina and Leo
>>> *Michaël Michaud
>>> *Sent:* Saturday, October 30, 2010 4:54 PM
>>> Hi Ravi,
>>> Did you try to update your jdbc driver ?
>>> Again, there is a link here to download it :
>>> http://jdbc.postgresql.org/download.html
>>> You should download
>>> http://jdbc.postgresql.org/download/postgresql-9.0-801.jdbc3.jar
>>> <http://jdbc.postgresql.org/download/postgresql-9.0-801.jdbc4.jar>
>>> Then, you have to go in your OpenJUMP intallation directory and replace
>>> postgresql-8.3-603.jdbc3.jar
>>> by
>>> If you're using java6, you should be able to use 9.0-801 JDBC 4
>>> instead of 9.0-801 JDBC 3
>>> Note that I haven't yet install postgresql 9.0 to check everything
>>> is fine, but it comes from a discussion I had with postgis
>>> developpers that something changed in the postgresql 9.0 byte array
>>> format, which is the reason why a new driver is required.
>>> Hope that helps
>>> Michaël
>>> Le 30/10/2010 21:06, Ravi a écrit :
>>>> ST_AsBinary
>>>> Other that OpenJUMP, suggest which FOSS4G tool can be used.
>>>> Finding some road blocks using
>>>> PostGIS and Seeing it on OpenJUMP.
>>>> Ravi Kumar
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101101/1917343c/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101101/1917343c/attachment.png>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101101/1917343c/attachment-0001.png>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101101/1917343c/attachment.obj>
