[postgis-users] Fix "Ring self-intersection" problem
Kevin Neufeld
kneufeld at refractions.net
Mon Nov 1 20:04:58 PDT 2010
On 11/1/2010 4:29 PM, ByronCinNz wrote:
> SELECT
> ST_BuildArea(
> ST_Union(
> ‘LINESTRING EMPTY’,
> ST_ExteriorRing(
> ‘POLYGON((...))’
> The circumstances in which this method fails is when there are interior
> rings inside the invalid polygon.
> The interior rings disappear - which would be expected because the process
> is only looking for exterior rings.
Try using ST_Boundary() instead of ST_ExteriorRing(). It will return
the linework that makes up a polygon (the exterior and interior rings).
You could also try buffering your polygon by 0, ST_Buffer(geom, 0).
This has the side effect of deconstructing and reconstructing your polygon.
-- Kevin
