[postgis-users] Check-Constraint »enforce_geotype_poly« violated
Jan Saalbach fire at dubmosphere.de
Tue Nov 2 07:30:49 PDT 2010
Dear All,
when trying to insert a polygon into a table from a plperl script by
this command:
my $new_poly = spi_exec_query("INSERT INTO polys1(id,poly)
VALUES($new_id, ST_MakeEnvelope($xmin, $ymin , $xmax, $ymax, 31467));");
I get a
"new row for relation »polys1« violates Check-Constraint
»enforce_geotype_poly«"
What I think it means is that only a POLYGON can be inserted. Now,
previously (not from a plperl script) the same INSERT command with
MakeEnvelope worked just fine on a table with the exact same structure
and properties.
The Column was created using
SELECT AddGeometryColumn('polys1','poly',31467,'POLYGON', 2);
How can I get this INSERT command to work? Any suggestions?
Regards
Jan
