[postgis-users] Query using ST_transform fails
Torsten Mohr
tmohr at s.netic.de
Tue Nov 2 14:09:45 PDT 2010
Hello,
(i accidentially posted this on the openstreetmap mailing list, but it
belongs here:)
I once got a hint on this mailing list to use a query like this to get the
lat/lon of the world capitals:
A)
select st_X(wayLL), st_Y(wayLL), name from (select
ST_AsText(ST_Transform(way,4326)) as wayLL, name from planet_osm_point where
capital='yes') as foo limit 5;
B)
Based on that hint i used this query:
select st_X(st_transform(way,4326)), st_Y(st_transform(way,4326)), name from
planet_osm_point where place='city' and capital='yes';
That query worked fine and i did not change my system since then (that somehow
can't be true). I now get errors for both queries:
FEHLER: transform: couldn't project point (653103 6.63036e+06 0): failed to
load NAD27-83 correction file (-38)
TIP: PostGIS was unable to transform the point because either no grid shift
files were found, or the point does not lie within the range for which the
grid shift is defined. Refer to the ST_Transform() section of the PostGIS
manual for details on how to configure PostGIS to alter this behaviour.
Could it be that due to an RPM update of PostgreSQL some scripts need to be
reinstalled? I can still generate maps using mapnik.
What do i need to do to make those queries work again?
In a second step i'd like to extract the polygons that make up the borders
of a country as lat/lon values. I wonder if this is possible by just applying
the SQL query above to the way of a polygon? Or is there another way to
get the data i want?
Thanks for any hints,
Torsten.
