[postgis-users] suitable projection in metric system ?
Andreas Forø Tollefsen
andreasft at gmail.com
Fri Nov 5 01:48:25 PDT 2010
Thanks for this info.
Could someone recommend a global metric projection as well? I need to use
the geometry type due to some functions in postgis.
2010/11/5 Francis Markham <fmarkham at gmail.com>
> Hi Ahmet,
> My quick Googling hasn't come up with a widely used pre-defined projection
> for Turkey that is non zonal (either UTM or Gauss-Kruger), at least not in
> the EPSG database. Apparently, MapInfo ships with a Turkish Lambert
> projection in its mapinfow.prj<http://testdrive.mapinfo.com/techsupp/miprod.nsf/8248bf2b72f6949585257125006b035a/215efdb0c93153be85256a410055416a?OpenDocument>file, which is widely available on the web. I took the parameters from that
> projection and created an entry on spatialreference.org<http://spatialreference.org/ref/sr-org/7006/>as SR-ORG:7006. This can be inserted into PostGIS as a new SRS as:
> INSERT into spatial_ref_sys (srid, auth_name, auth_srid, proj4text, srtext) values ( 97006, 'sr-org', 7006, '', 'PROJCS["Turkish Lambert Conformal (K.Eren - ED50)",GEOGCS["GCS_European_1950",DATUM["D_European_1950",SPHEROID["International_1924",6378388.0,297.0]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Lambert_Conformal_Conic"],PARAMETER["False_Easting",1003827.0],PARAMETER["False_Northing",-1183453.0],PARAMETER["Central_Meridian",36.0],PARAMETER["Standard_Parallel_1",37.5],PARAMETER["Standard_Parallel_2",40.5],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",25.0],UNIT["Meter",1.0]]');
> This can then be used as SRS number 97006.
> Note that this projection uses the ED50 datum. If your coordinates are in
> WGS84 (the standard for GPS) or some other datum, it might be convenient to
> create a new SRS using the above parameters but based on another datum.
> Furthermore, If you are happy to keep your data in geographic coordinates
> (lat/lon) you may wish to investigate the Geography type as Emily
> suggested. Be aware, however, that this has some cost in terms of speed for
> some operations, and not all operations defined in PostGIS for Geometry are
> currently available for Geography types.
> Good luck,
> Francis Markham
> 2010/11/5 ahmet temiz <ahmettemiz88 at gmail.com>
> hello
>> I was wondering if you could tell me which projection in metric system
>> is suitable for whole country (TURKEY) ?
>> I thought to use UTM, but it has three different zones.
>> If you answer me, I will appreciate
>> regards
>> Ahmet Temiz
>> Jeoloji Müh.
>> Planlama ve Zarar Azaltma Dairesi Başkanlığı
>> Bilgi ve CBS grubu
>> Eskişehir Yolu 10. km.
>> Lodumlu / Ankara
>> Tel : 0 312 2872680 / 1535
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101105/a027d613/attachment.html>
