[postgis-users] Announcement: PostGIS Versioning System pgversion and QGIS Plugin
Düster Horst
Horst.Duester at bd.so.ch
Mon Nov 8 01:21:58 PST 2010
The plugin is marked as experimental and I had set the qgis minimum
version to 1.5 due to I tested the plugin with 1.5. I changed the
minimum version 1.4. Please try it and give me a responce whether it
works.
Regards
Horst
Dr. Horst Düster
Stv. Amtschef / kantonaler GIS-Koordinator
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Mobil ++41(0)79 511 54 12
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
-----Ursprüngliche Nachricht-----
Von: maning sambale [mailto:emmanuel.sambale at gmail.com]
Gesendet am: Montag, 8. November 2010 10:10
An: PostGIS Users Discussion
Betreff: Re: [postgis-users] Announcement: PostGIS Versioning System
Nice! What version of QGIS does it use. I added your repoe, but I
can't find the plugin in my 1.4 version
On Mon, Nov 8, 2010 at 4:08 PM, Javier de la Torre
<jatorre at vizzuality.com> wrote:
> Hi,
> Thats great. Congratulations.
> One question. If I understand correctly you are using the DB users for
the
> versioning. How easy would be to use external users from, for example
a web
> system? We normally do not use the users on PostgreSQL for the data
content.
> Are you planning something on this direction?
> Thanks.
> Javier
> www.vizzuality.com
> On Nov 8, 2010, at 8:43 AM, Düster Horst wrote:
> I just finished the first beta version of my newly released pgvs
support
> system. The idea of this system is to enable the editing of a single
> layer concurrently by more than one user at the same time, similar to
source
> code versioning systems like CVS or Subversion. You will find further
> informations at:
> http://www.kappasys.org/cms/index.php?id=23&L=5
> You can download the PostGIS functions from:
> http://www.kappasys.ch/pgtools/pgversion/createFunctions.sql
> To get easy access to pgvs I additionally created the QGIS plugin
pgversion
> which you can download from:
> http://www.kappasys.org/qgis/plugins.xml
> I know that not all features of a SVN like system are implemented yet.
But I
> would like to get your comments and ideas for further developements.
> I hope that pgvs can make your life easier.
> Regards
> Horst
> Dr. Horst Düster
> Kanton Solothurn
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> postgis-users mailing list
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101108/e692e974/attachment.html>
