[postgis-users] Announcement: PostGIS Versioning System pgversion and QGIS Plugin
Düster Horst
Horst.Duester at bd.so.ch
Mon Nov 8 03:02:42 PST 2010
Did you install pgvs in your postgres db?
Dr. Horst Düster
Stv. Amtschef / kantonaler GIS-Koordinator
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Mobil ++41(0)79 511 54 12
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
-----Ursprüngliche Nachricht-----
Von: maning sambale [mailto:emmanuel.sambale at gmail.com]
Gesendet am: Montag, 8. November 2010 10:58
An: Düster Horst
Cc: postgis-users
Betreff: Re: Re: [postgis-users] Announcement: PostGIS Versioning System
On QGIS 1.4 (mac), I overridden the 1.5 warning and continued with the
install. Plugin manager didn't activate it.
On qgis 1.5.0 (ubuntu):
I had to install qtsql. Then the plugin was activated. Tested with
my test postgis data, I got this error when I used "Prepare layer for
versioning":
An error has occured while executing Python code:
File "/home/maning/.qgis/python/plugins/pgversion/pgVersion.py",
line 170, in doInit
if not self.tools.versionExists(mySchema, myTable):
File "/home/maning/.qgis/python/plugins/pgversion/pgVersionTools.py",
line 107, in versionExists
if len(result["SCHEMA"]) 0:
KeyError: 'SCHEMA'
Python version:
2.6.5 (r265:79063, Apr 16 2010, 13:28:26)
[GCC 4.4.3]
QGIS version:
1.5.0-Tethys Tethys, exported
Python path: ['/usr/share/qgis/python', '/home/maning/.qgis/python',
'/home/maning/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
'/usr/local/lib/python2.6/dist-packages/Sphinx-0.6.5-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/docutils-0.6-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/Jinja2-2.4.1-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/Pygments-1.3.1-py2.6.egg',
'/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
'/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
'/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
'/usr/lib/python2.6/dist-packages/PIL',
'/usr/lib/python2.6/dist-packages/gst-0.10',
'/usr/lib/pymodules/python2.6',
'/usr/lib/python2.6/dist-packages/gtk-2.0',
'/usr/lib/pymodules/python2.6/gtk-2.0',
'/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode',
'/usr/local/lib/python2.6/dist-packages',
u'/home/maning/.qgis//python/plugins',
'/usr/share/qgis/python/plugins/fTools/tools']
On Mon, Nov 8, 2010 at 5:21 PM, Düster Horst <Horst.Duester at bd.so.ch>
wrote:
> The plugin is marked as experimental and I had set the qgis minimum
version
> to 1.5 due to I tested the plugin with 1.5. I changed the minimum
version
> 1.4. Please try it and give me a responce whether it works.
> Regards
> Horst
> Dr. Horst Düster
> Kanton Solothurn
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Gesendet am: Montag, 8. November 2010 10:10
> An: PostGIS Users Discussion
> Betreff: Re: [postgis-users] Announcement: PostGIS Versioning System
> Nice! What version of QGIS does it use. I added your repoe, but I
> can't find the plugin in my 1.4 version
> On Mon, Nov 8, 2010 at 4:08 PM, Javier de la Torre
> <jatorre at vizzuality.com> wrote:
>> Hi,
>> Thats great. Congratulations.
>> One question. If I understand correctly you are using the DB users
for the
>> versioning. How easy would be to use external users from, for example
a
>> web
>> system? We normally do not use the users on PostgreSQL for the data
>> content.
>> Are you planning something on this direction?
>> Thanks.
>> Javier
>> www.vizzuality.com
>> On Nov 8, 2010, at 8:43 AM, Düster Horst wrote:
>> I just finished the first beta version of my newly released pgvs
support
>> system. The idea of this system is to enable the editing of a single
>> PostGIS
>> layer concurrently by more than one user at the same time, similar to
>> source
>> code versioning systems like CVS or Subversion. You will find further
>> informations at:
>> http://www.kappasys.org/cms/index.php?id=23&L=5
>> You can download the PostGIS functions from:
>> http://www.kappasys.ch/pgtools/pgversion/createFunctions.sql
>> To get easy access to pgvs I additionally created the QGIS plugin
>> pgversion
>> which you can download from:
>> http://www.kappasys.org/qgis/plugins.xml
>> I know that not all features of a SVN like system are implemented
yet. But
>> I
>> would like to get your comments and ideas for further developements.
>> I hope that pgvs can make your life easier.
>> Regards
>> Horst
>> Dr. Horst Düster
>> Kanton Solothurn
>> SO!GIS Koordination
>> Rötistrasse 4
>> CH-4501 Solothurn
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
cheers,
maning
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101108/c862d838/attachment.html>
