[postgis-users] Announcement: PostGIS Versioning System pgversion and QGIS Plugin
maning sambale
emmanuel.sambale at gmail.com
Mon Nov 8 03:37:03 PST 2010
Sweet! It's working on qgis 1.5 (ubuntu). Will be watching this
plugin. Thanks!
On Mon, Nov 8, 2010 at 7:13 PM, Düster Horst <Horst.Duester at bd.so.ch> wrote:
> I made an update to handle a non existing pgvs in the layers source db.
> Please reinstall the plugin and try again.
> Dr. Horst Düster
> Stv. Amtschef / kantonaler GIS-Koordinator
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Mobil ++41(0)79 511 54 12
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch
> -----Ursprüngliche Nachricht-----
> Von: emmanuel.sambale at gmail.com [mailto:emmanuel.sambale at gmail.com]
> Gesendet am: Montag, 8. November 2010 10:58
> An: Düster Horst
> Cc: postgis-users
> Betreff: Re: Re: [postgis-users] Announcement: PostGIS Versioning System
> On QGIS 1.4 (mac), I overridden the 1.5 warning and continued with the
> install. Plugin manager didn't activate it.
> On qgis 1.5.0 (ubuntu):
> I had to install qtsql. Then the plugin was activated. Tested with
> my test postgis data, I got this error when I used "Prepare layer for
> versioning":
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "/home/maning/.qgis/python/plugins/pgversion/pgVersion.py",
> line 170, in doInit
> if not self.tools.versionExists(mySchema, myTable):
> File "/home/maning/.qgis/python/plugins/pgversion/pgVersionTools.py",
> line 107, in versionExists
> if len(result["SCHEMA"]) 0:
> KeyError: 'SCHEMA'
> Python version:
> 2.6.5 (r265:79063, Apr 16 2010, 13:28:26)
> [GCC 4.4.3]
> QGIS version:
> 1.5.0-Tethys Tethys, exported
> Python path: ['/usr/share/qgis/python', '/home/maning/.qgis/python',
> '/home/maning/.qgis/python/plugins', '/usr/share/qgis/python/plugins',
> '/usr/local/lib/python2.6/dist-packages/Sphinx-0.6.5-py2.6.egg',
> '/usr/local/lib/python2.6/dist-packages/docutils-0.6-py2.6.egg',
> '/usr/local/lib/python2.6/dist-packages/Jinja2-2.4.1-py2.6.egg',
> '/usr/local/lib/python2.6/dist-packages/Pygments-1.3.1-py2.6.egg',
> '/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
> '/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
> '/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
> '/usr/lib/python2.6/dist-packages/PIL',
> '/usr/lib/python2.6/dist-packages/gst-0.10',
> '/usr/lib/pymodules/python2.6',
> '/usr/lib/python2.6/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.6/gtk-2.0',
> '/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode',
> '/usr/local/lib/python2.6/dist-packages',
> u'/home/maning/.qgis//python/plugins',
> '/usr/share/qgis/python/plugins/fTools/tools']
> On Mon, Nov 8, 2010 at 5:21 PM, Düster Horst <Horst.Duester at bd.so.ch> wrote:
>> The plugin is marked as experimental and I had set the qgis minimum
>> version
>> to 1.5 due to I tested the plugin with 1.5. I changed the minimum version
>> 1.4. Please try it and give me a responce whether it works.
>> Regards
>> Horst
>> Dr. Horst Düster
>> Kanton Solothurn
>> SO!GIS Koordination
>> Rötistrasse 4
>> CH-4501 Solothurn
>> Von: maning sambale [mailto:emmanuel.sambale at gmail.com]
>> Gesendet am: Montag, 8. November 2010 10:10
>> An: PostGIS Users Discussion
>> Betreff: Re: [postgis-users] Announcement: PostGIS Versioning System
>> Nice! What version of QGIS does it use. I added your repoe, but I
>> can't find the plugin in my 1.4 version
>> On Mon, Nov 8, 2010 at 4:08 PM, Javier de la Torre
>> <jatorre at vizzuality.com> wrote:
>>> Hi,
>>> Thats great. Congratulations.
>>> One question. If I understand correctly you are using the DB users for
>>> the
>>> versioning. How easy would be to use external users from, for example a
>>> web
>>> system? We normally do not use the users on PostgreSQL for the data
>>> content.
>>> Are you planning something on this direction?
>>> Thanks.
>>> Javier
>>> www.vizzuality.com
>>> On Nov 8, 2010, at 8:43 AM, Düster Horst wrote:
>>> I just finished the first beta version of my newly released pgvs support
>>> system. The idea of this system is to enable the editing of a single
>>> PostGIS
>>> layer concurrently by more than one user at the same time, similar to
>>> source
>>> code versioning systems like CVS or Subversion. You will find further
>>> informations at:
>>> http://www.kappasys.org/cms/index.php?id=23&L=5
>>> You can download the PostGIS functions from:
>>> http://www.kappasys.ch/pgtools/pgversion/createFunctions.sql
>>> To get easy access to pgvs I additionally created the QGIS plugin
>>> pgversion
>>> which you can download from:
>>> http://www.kappasys.org/qgis/plugins.xml
>>> I know that not all features of a SVN like system are implemented yet.
>>> But
>>> I
>>> would like to get your comments and ideas for further developements.
>>> I hope that pgvs can make your life easier.
>>> Regards
>>> Horst
>>> Dr. Horst Düster
>>> Kanton Solothurn
>>> SO!GIS Koordination
>>> Rötistrasse 4
>>> CH-4501 Solothurn
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> cheers,
>> maning
>> "Freedom is still the most radical idea of all" -N.Branden
>> wiki: http://esambale.wikispaces.com/
>> blog: http://epsg4253.wordpress.com/
> cheers,
> maning
cheers,
maning
