[postgis-users] help with pgsql2shp error
strk strk at keybit.net
Tue Nov 9 00:29:31 PST 2010
On Mon, Nov 08, 2010 at 01:10:00PM -0500, Sam Snellings wrote:
> I didn't check the log, do you still need that to diagnose or did your
> second reply mean it's not necessary?
Until you figure out what it is I'd recommend looking at it.
> *(database geog_three, tutorial data) select
> GeomFromEWKB(asEWKB(geog::geometry)) from airports;*
> 0101000020E610000075029A081B9A5DC0F085C954C1F84040
> 0101000020E61000006DC5FEB27B720440454772F90F814840
> 0101000020E610000022FDF675E0DC35C000917EFB3A085040
> all of which match the entries in the_geom for that table.
> Does an EWKB validator exist?
Well, yes. The parser does validation.
The weird thing is that the parser invoked by your dumper
fails the validation, while the (supposedly) same parser
invoked by postgis succeeds.
I just tried creating a table with a single geography field,
copying the HEXEWKB above into it and then dumping it.
Had no problem. Can you try it ?
name=test`date +"%Y%m%d%H%M%S"`
psql -f - <<EOF && pgsql2shp ${USER} ${name}
create table "${name}" (g geography);
copy "${name}" from stdin;
EOF
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
