[postgis-users] massive snap of points of one geometry to points of another geometry
Jose C. Martinez-Llario jomarlla at cgf.upv.es
Tue Nov 16 04:18:12 PST 2010
Hi all,
JASPA has a ST_SNAP function using JTS function. I guess with GEOS
should be similar.
You can snap the segments and vertex of a geometry to the vertex of
anotther one.
http://jaspa.forge.osor.eu/ST_Snap.html
Anyways, in my opinion this algorithm should be modified a little bit to
use in a spatial database using real cartography.
Some interesting comments from Martin Davis to my question  in the jts list.
http://sourceforge.net/mailarchive/forum.php?thread_name=4C534B34.5090003%40cgf.upv.es&forum_name=jts-topo-suite-user
In JASPA 0.2 (maybe around march) a new system with topology rules and I
think a tolerance system will be introduced.
Hope it helps,
Jose
public static Geometry ST_Snap(Geometry geom0, Geometry geom1, double
tolerance) throws JASPAJTSException, JASPAGeomMismatchException {
         if (GeomProperties.errorIfDifferentSRIDorCoorDim (geom0,
geom1)) return null;
         GeometrySnapper snapper = new GeometrySnapper(geom0);
         Geometry res = null;
         try {
             res = snapper.snapTo(geom1, tolerance);
             Geometry[] snapped = GeometrySnapper.snap(geom0, geom1,
tolerance);
             if (snapped == null || snapped.length < 2) return null;
             Geometry res = snapped[0];
         } catch (RuntimeException e) {
             //Catch the runtime JTS Exceptions
             Core.manageJTSExceptions(e);
         return res;
El 16/11/2010 13:04, Jan Hartmann escribió:
> On 11/15/10 18:03, strk wrote:
>> The function exists within GEOS, which is a library used by PostGIS.
>> But the specific functionality (snapping) isn't exposed in SQL yet.
>> What you could do is implement or fund implementation of
>> the missing bit (the wrapper).
> I've always found snapping a very important function in all kinds of
> (carto)graphic environments. Could you give an indication how much
> time it would cost to write the PostGIS wrappers? If the algorithm
> already exists in GEOS, exposing it in PostGIS doesn't look like a
> major problem to me.
> Jan
> postgis-users mailing list
