[postgis-users] export polygon to shapefile problem
Thomas Kouk
thomaskouk at yahoo.gr
Wed Nov 17 03:56:54 PST 2010
Thanks Helen,
I've been trying to make it work. I don't have ogr2ogr.exe somewhere in
PostgreSQL folder. The only place where I have ogr2ogr.exe is in FWTools folder,
(other ones in OSGeo4W do not work, dll problems).
So I try this:
C:\Program Files\FWTools2.4.7\bin> ogr2ogr -a srs EPSG:27700 -f "ESRI Shapefile"
file.shp PG:"dbname=postgis host=localhost user=postgres password=postgres"
-sql "SELECT AsBinary(the_geom) as wkb_geometry FROM W_TQ2575_Buffer"
After this I do not get any error message, but I get the ogr2ogr usage
information (as if something I typed is wrong) and the file.shp is not created
(cannot be found anywhere).
Any help?
From: Helen San Segundo Navazo <hsansegundo at meteo.cat>
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Sent: Wed, November 17, 2010 9:29:15 AM
Subject: Re: [postgis-users] export polygon to shapefile problem
Hi Thomas,
I use the next expression to export data automatically in an script from a table
with polygons into a shape file:
ogr2ogr -a_srs EPSG:23031 -f "ESRI Shapefile" file.shp PG:"dbname=db_name
host=the_host user=the_user password=the_password" -sql "SELECT
AsBinary(the_geometry_column) as wkb_geometry, column2,column3,column4 etc. FROM
table where conditions"
I hope this will help you,
Helen
Thomas Kouk escribió:
> Hi all,
> I am newbie in PostGIS and I have a problem exporting a polygon table in shp. I
>want to export specific spatial tables from by database using a batch procedure
>(bat file). The command I use is:
> pgsql2shp -P [password] -f [shapefile path & name] postgis [tablename], for
>example: pgsql2shp -P postgres -f Data\Buffers\ Buffer.shp postgis buffer_table
> It works fine with all other spatial tables (linestring or multilinestring
>type). For polygons it also seems to work, as I get no error message:
> / Initializing... Done (postgis major version: 1)./
> / Output shape: Polygon/
> / Dumping: XX [1 rows]./
> However, when I try to load the polygon shp in Qgis or ArcGIS I get an error:
>ArcGIS cannot open the file, while QGIS loads the shp but displays nothing (as
>if the table is empty, which is not the case).
> All my tables are spatial tables with no information on geometry_columns table,
>but even if I add the polygon table in the geometry_columns, nothing changes.
>After all, the function works with all other spatial non polygon tables despite
>the fact that geometry_columns holds no information on them, so this is not the
>problem.
> I can load the postgis polygon table in qgis and export it manually to a shp,
>which works fine, but I need to do it in an automatic way using a command.
> Has anyone come to this problem or is there something I do not know about
>exporting polygon tables to shp?
> Thanks.
> postgis-users mailing list
http://www.meteo.cat
Tel. 93 567 60 90
Fax 93 567 61 02
A/e hsansegundo at meteo.cat <mailto:hsansegundo at meteo.cat>
Abans d’imprimir aquest correu, assegureu-vos que és del tot necessari. El medi
ambient és cosa de tothom!
La informació d'aquesta transmissió electrònica és confidencial i el seu ús sols
està permès als seus destinataris. Si Vostè no és la persona destinatària
d'aquesta transmissió electrònica, li preguem que ens ho comuniqui de forma
immediata i destrueixi qualsevol copia de la mateixa (tant digital com en
paper).
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101117/da5a2f55/attachment.html>
