[postgis-users] export polygon to shapefile problem
Thomas Kouk thomaskouk at yahoo.gr
Wed Nov 17 04:40:18 PST 2010
Hi Marco,
I tried the sql statement in psql, it works fine, no error message.
There is no error message right above the usage information.
I do not want to reproject, polygon is already in SRID 27700.
The table's name could be the problem, because in pgadmin sql window or psql
window it needs quotation (""). So I created a new table like the old one, only
with a simpler name. I tried again, but still with no results:
ogr2ogr -a -f "ESRI Shapefile" file.shp PG:"dbname=postgis host=localhost
user=postgres password=postgres" -sql "SELECT AsBinary(the_geom) as wkb_geometry
FROM test"
Is there any other way?
Thanks
From: Marco Lechner - FOSSGIS e.V. <marco.lechner at fossgis.de>
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Sent: Wed, November 17, 2010 12:07:27 PM
Subject: Re: [postgis-users] export polygon to shapefile problem
try
C:\Program Files\FWTools2.4.7\bin>ogr2ogr -a srs "EPSG:27700" ...
Does your sql-statemnet produce a result when executed within psql?
Are you sure there's no error message right above the usage information?
Do you want to reproject to 27700? Then you should use -t_srs
Marco
Am 17.11.2010 12:56, schrieb Thomas Kouk:
Thanks Helen,
>I've been trying to make it work. I don't have ogr2ogr.exe somewhere in
>PostgreSQL folder. The only place where I have ogr2ogr.exe is in FWTools folder,
>(other ones in OSGeo4W do not work, dll problems).
>So I try this:
>C:\Program Files\FWTools2.4.7\bin> ogr2ogr -a srs EPSG:27700 -f "ESRI Shapefile"
>file.shp PG:"dbname=postgis host=localhost user=postgres password=postgres"
>-sql "SELECT AsBinary(the_geom) as wkb_geometry FROM W_TQ2575_Buffer"
>After this I do not get any error message, but I get the ogr2ogr usage
>information (as if something I typed is wrong) and the file.shp is not created
>(cannot be found anywhere).
>Any help?
From: Helen San Segundo Navazo <hsansegundo at meteo.cat>
>Sent: Wed, November 17, 2010 9:29:15 AM
>Hi Thomas,
>I use the next expression to export data automatically in an script from a table
>with polygons into a shape file:
>ogr2ogr -a_srs EPSG:23031 -f "ESRI Shapefile" file.shp PG:"dbname=db_name
>host=the_host user=the_user password=the_password" -sql "SELECT
>AsBinary(the_geometry_column) as wkb_geometry, column2,column3,column4 etc. FROM
>table where conditions"
>I hope this will help you,
>Helen
>Thomas Kouk escribió:
>> Hi all,
>> I am newbie in PostGIS and I have a problem exporting a polygon table in shp. I
>>want to export specific spatial tables from by database using a batch procedure
>>(bat file). The command I use is:
>> pgsql2shp -P [password] -f [shapefile path & name] postgis [tablename], for
>>example: pgsql2shp -P postgres -f Data\Buffers\ Buffer.shp postgis buffer_table
>> It works fine with all other spatial tables (linestring or multilinestring
>>type). For polygons it also seems to work, as I get no error message:
>> / Initializing... Done (postgis major version: 1)./
>> / Output shape: Polygon/
>> / Dumping: XX [1 rows]./
>> However, when I try to load the polygon shp in Qgis or ArcGIS I get an error:
>>ArcGIS cannot open the file, while QGIS loads the shp but displays nothing (as
>>if the table is empty, which is not the case).
>> All my tables are spatial tables with no information on geometry_columns table,
>>but even if I add the polygon table in the geometry_columns, nothing changes.
>>After all, the function works with all other spatial non polygon tables despite
>>the fact that geometry_columns holds no information on them, so this is not the
>>problem.
>> I can load the postgis polygon table in qgis and export it manually to a shp,
>>which works fine, but I need to do it in an automatic way using a command.
>> Has anyone come to this problem or is there something I do not know about
>>exporting polygon tables to shp?
>> Thanks.
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>http://www.meteo.cat
>Tel. 93 567 60 90
>Fax 93 567 61 02
>A/e hsansegundo at meteo.cat <mailto:hsansegundo at meteo.cat>
>Abans d’imprimir aquest correu, assegureu-vos que és del tot necessari. El medi
>ambient és cosa de tothom!
>La informació d'aquesta transmissió electrònica és confidencial i el seu ús sols
>està permès als seus destinataris. Si Vostè no és la persona destinatària
>d'aquesta transmissió electrònica, li preguem que ens ho comuniqui de forma
>immediata i destrueixi qualsevol copia de la mateixa (tant digital com en
>paper).
> _______________________________________________ postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101117/2200d868/attachment.html>
