[postgis-users] How could I improve this query?
Kevin Neufeld
kneufeld at refractions.net
Tue Nov 23 10:26:07 PST 2010
Interesting thought. Note though, Benjamin, that Jorge specified
"a.min", not "b.min" in the filter clause.
-- Kevin
On 11/23/2010 10:07 AM, Benjamin Juhn wrote:
> You're current query is likely exploding your result set when table_a
> records intersect with more than one record in table_b. Assuming
> there is no overlap of min & max values in table_b the following query
> will stop testing for intersection between a & c records after find
> one so it should run faster:
> UPDATE table_a a SET integer_field = b.integer_field
> FROM table_b b
> WHERE a.integer_field2 <= b.max AND a.integer_field2 >= b.min
> AND EXISTS (SELECT true FROM table_c c WHERE st_intersects(a.geom,
> c.geom) LIMIT 1);
> also I'm assuming you meant to reference b.min here:
>> table_a.integer_field2 >=
>> table_a.min
> On Nov 23, 2010, at 9:48 AM, David William Bitner wrote:
>> Jorge,
>> What does running "explain analyze" give you for that query?
>> db
>> 2010/11/23 Jorge Arévalo <jorge.arevalo at deimos-space.com
>> <mailto:jorge.arevalo at deimos-space.com>>
>> Hello all,
>> The query:
>> update table_a set integer_field = table_b.integer_field from
>> table_c,
>> table_b where table_b.string_field = table_c.string_field and
>> table_a.integer_field2 <= table_b.max and table_a.integer_field2 >=
>> table_a.min and st_intersects(table_a.geom, table_c.geom)
>> Context:
>> - Ubuntu 10.04, PostgreSQL 8.4.5, PostGIS 1.4.0, GEOS 3.1.0, PROJ
>> 4.7.1
>> - table_a: a table with ~ 1500000 records. One geometry column of
>> type
>> POLYGON. SRID 23030, UTM coords.
>> - table_b: a table with 3 integer fields and one string field. 88
>> records.
>> - table_c: a table with ~ 69000 records. One geometry column of type
>> - Indexes: GiST on geometry columns, btree in min, max (table_b),
>> The query takes about 15 min to finish in a 8-core Intel(R) Xeon
>> 2.50GHz, with 3 GB RAM. Would it be possible to reduce this time?
>> I've
>> changed some parameters in postgresql.conf, like "shared_buffers"
>> Things I think I could do (need to test it):
>> - Change the string comparison by an integer-based one (I have only a
>> limited set of string values).
>> - Clustering geom indexes?
>> Any suggestion welcome.
>> Thanks in advance,
>> Jorge Arévalo
>> Internet & Mobilty Division, DEIMOS
>> http://mobility.grupodeimos.com/
>> http://gis4free.wordpress.com <http://gis4free.wordpress.com/>
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> <mailto:postgis-users at postgis.refractions.net>
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101123/c9a822cb/attachment.html>
