[postgis-users] Benshmark postgis
George Silva
georger.silva at gmail.com
Thu Nov 25 10:30:51 PST 2010
To eliminate the problemas presented by Paul, create a regular grid of 1x1
degrees and populate it randomly with points. Then make your test. All
square polygons will have 4 vertexes and the test is "less biased".
George
On Thu, Nov 25, 2010 at 3:22 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Depends on who you think the results will be valid for. The
> countries-of-the-world is a somewhat non-standard GIS collection given
> the wide variation in polygon sizes, the large numbers of vertices in
> the larger polygons, and the extreme coverage of the overall area that
> the bounding boxes of the larger polygons command. In many ways your
> test of "against the whole world" will be largely a test of "against
> Russia, Canada, Brazil, and the USA"
> Data matters,
> P
> On Thu, Nov 25, 2010 at 9:16 AM, Arnaud Vandecasteele
> <arnaud.sig at gmail.com> wrote:
> Hi all,
> > I've to do a quick benchmark of postgis. The case is to check if a
> > point is inside (or not) a polygon.
> > To do so, I've uploaded in my database a big shapefile which contains
> > all the world's countries.
> > After that I've made a simple stored function [1]. This one, take two
> > arguments :
> > 1 - The number of points to check
> > 2 - The number of polygon to check
> > Then I run the query and i change the number of iterations or the
> > number of feature.
> > Do you think it's a good way to have some pertinents results ?
> > Best regards
> > Arnaud
> > [1]
> > -- Function: random_poi(integer, integer)
> > -- DROP FUNCTION random_poi(integer, integer);
> > CREATE OR REPLACE FUNCTION random_poi(integer, integer)
> > RETURNS void AS
> > $BODY$
> > DECLARE
> > iteration alias for $1;
> > nb_feat alias for $2;
> > pt_x numeric;
> > pt_y numeric;
> > geom_poi geometry;
> > i int := 0;
> > BEGIN
> > WHILE i < iteration LOOP
> > i := i + 1;
> > -- CREATE RANDOM POSITION
> > pt_x := random()*100;
> > pt_y := random()*100;
> > -- CREATE RANDOM GEOM POI
> > geom_poi := ST_GeometryFromText(text 'POINT('||pt_x||'
> '||pt_y||')');
> > PERFORM ST_CONTAINS(geom_poi, the_geom) FROM world_poly
> LIMIT nb_feat;
> > END LOOP;
> > return;
> > END;
> > $BODY$
> > LANGUAGE 'plpgsql' IMMUTABLE STRICT
> > COST 100;
> > ALTER FUNCTION random_poi(integer, integer) OWNER TO postgres;
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
George R. C. Silva
Desenvolvimento em GIS
http://blog.geoprocessamento.net
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101125/1c3f9893/attachment.html>
