[postgis-users] Can't Find liblwgeom for WKT Raster Installation
fueldistributa jeanbouffard at gmail.com
Fri Nov 26 08:12:34 PST 2010
fueldistributa wrote:
> Hi
> I'm currently working on setting-up a spatial database on Ubuntu (10.04
> LTS lycid lynx).  I've installed postgresql 8.4 / postgis 1.5.2 using the
> synaptic manager command line method in the terminal. I've verified that I
> have all the necessary requirements, but cannot seem to get pass the
> ./configure to try and install WKT Raster.
> This is the following error message that I get, after running the
> configure line in the wktraster0.1.6d folder;
> "sudo ./configure
> --with-postgis-sources=/usr/share/postgresql/8.4/contrib/postgis-1.5"
> I've pasted the entire ./configure output in case there is something else
> I'm missing, but the error is at the bottom.
> error:
> checking build system type... x86_64-unknown-linux-gnu
> checking host system type... x86_64-unknown-linux-gnu
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ANSI C... none needed
> checking for a sed that does not truncate output... /bin/sed
> checking for egrep... grep -E
> checking for ld used by gcc... /usr/bin/ld
> checking if the linker (/usr/bin/ld) is GNU ld... yes
> checking for /usr/bin/ld option to reload object files... -r
> checking for BSD-compatible nm... /usr/bin/nm -B
> checking whether ln -s works... yes
> checking how to recognise dependent libraries... pass_all
> checking how to run the C preprocessor... gcc -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking dlfcn.h usability... yes
> checking dlfcn.h presence... yes
> checking for dlfcn.h... yes
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking how to run the C++ preprocessor... g++ -E
> checking for g77... no
> checking for f77... no
> checking for xlf... no
> checking for frt... no
> checking for pgf77... no
> checking for fort77... no
> checking for fl32... no
> checking for af77... no
> checking for f90... no
> checking for xlf90... no
> checking for pgf90... no
> checking for epcf90... no
> checking for f95... f95
> checking whether we are using the GNU Fortran 77 compiler... yes
> checking whether f95 accepts -g... yes
> checking the maximum length of command line arguments... 32768
> checking command to parse /usr/bin/nm -B output from gcc object... ok
> checking for objdir... .libs
> checking for ar... ar
> checking for ranlib... ranlib
> checking for strip... strip
> checking if gcc supports -fno-rtti -fno-exceptions... no
> checking for gcc option to produce PIC... -fPIC
> checking if gcc PIC flag -fPIC works... yes
> checking if gcc static flag -static works... yes
> checking if gcc supports -c -o file.o... yes
> checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports
> shared libraries... yes
> checking whether -lc should be explicitly linked in... no
> checking dynamic linker characteristics... GNU/Linux ld.so
> checking how to hardcode library paths into programs... immediate
> checking whether stripping libraries is possible... yes
> checking if libtool supports shared libraries... yes
> checking whether to build shared libraries... yes
> checking whether to build static libraries... yes
> configure: creating libtool
> appending configuration tag "CXX" to libtool
> checking for ld used by g++... /usr/bin/ld -m elf_x86_64
> checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
> checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports
> checking for g++ option to produce PIC... -fPIC
> checking if g++ PIC flag -fPIC works... yes
> checking if g++ static flag -static works... yes
> checking if g++ supports -c -o file.o... yes
> appending configuration tag "F77" to libtool
> checking for f95 option to produce PIC... -fPIC
> checking if f95 PIC flag -fPIC works... yes
> checking if f95 static flag -static works... yes
> checking if f95 supports -c -o file.o... yes
> checking whether the f95 linker (/usr/bin/ld -m elf_x86_64) supports
> checking for gcc... (cached) gcc
> checking whether we are using the GNU C compiler... (cached) yes
> checking whether gcc accepts -g... (cached) yes
> checking for gcc option to accept ANSI C... (cached) none needed
> checking whether we are using the GNU C++ compiler... (cached) yes
> checking whether g++ accepts -g... (cached) yes
> checking if f95 supports -Wall... no
> checking if f95 supports -Wmissing-prototypes... no
> checking for flex... flex
> checking for yywrap in -lfl... yes
> checking lex output file root... lex.yy
> checking whether yytext is a pointer... yes
> checking for bison... bison -y
> checking for xsltproc... /usr/bin/xsltproc
> checking for db2pdf... no
> configure: WARNING: db2pdf is not installed so PDF documentation cannot be
> built
> checking for dblatex... no
> configure: WARNING: dblatex is not installed so PDF documentation cannot
> be built
> configure: WARNING: could not locate Docbook stylesheets required to build
> the documentation
> checking for low-level RASTER API debug mode... disabled
> checking for PostGIS RASTER activity debug mode... disabled
> checking for PostGIS RASTER memory activity debug mode... disabled
> checking CUnit/CUnit.h usability... no
> checking CUnit/CUnit.h presence... no
> checking for CUnit/CUnit.h... no
> configure: WARNING: could not locate CUnit required for liblwgeom unit
> tests
> checking iconv.h usability... yes
> checking iconv.h presence... yes
> checking for iconv.h... yes
> checking for iconv_open in -lc... yes
> checking for pg_config... /usr/bin/pg_config
> checking libpq-fe.h usability... yes
> checking libpq-fe.h presence... yes
> checking for libpq-fe.h... yes
> checking for PQserverVersion in -lpq... yes
> checking for development mode... disabled
> checking for GDAL... yes
> checking for GDAL version... 1.7.2
> configure: error: /usr/share/postgresql/8.4/contrib/postgis-1.5 does not
> contain liblwgeom/liblwgeom.h or lwgeom/liblwgeom.h, try
> --with-postgis-sources=DIR (requires postgis svn version)
> So I've read in a post that liblwgeom was renamed in newer versions of
> postgis. I'm assuming its the postgis-1.5.so file.
> How can I get my ./configure to work so I continue with a make & make
> install?
> What will I need to do, to get around this liblwgeom issue?
> I've searched the web with no luck trying to solve this issue, any help
> would be greatly appreciated.
> Thank you
> Jean B.
I've resolved this issue by simply getting the latest SVN snapshot of
postgis2.0.
Thanks.
View this message in context: http://old.nabble.com/Can%27t-Find-liblwgeom-for-WKT-Raster-Installation-tp30308500p30308929.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
