[postgis-users] [Qgis-developer] Fwd: WKTRaster Plugin 0.1
Maurício de Paulo mauricio.dev at gmail.com
Mon Nov 29 17:04:00 PST 2010
I've been using GDAL 1.7 and postgis 1.5.1
Both postgis' windows and ubuntu versions are able to load the rasters fine.
We've encountered some trouble with what we believe is the "regular
blocking" issue.
wktraster's QGIS plugin and MapServer source were tested on ubuntu 10.04
with ubuntugis binaries.
Perfomance looks like a huge issue at the moment. I didn't investigate why.
I can probably take look back at this issue when I get back home to my
ubuntu box. I can't test on windows because there is no QGIS compiled with
gdal 1.7 for windows prebuilt.
This new gdal driver version was included in which gdal release? Maybe we
can recompile everything and test again.
Best regards,
Mauricio
2010/11/29 Jorge Arévalo <jorge.arevalo at deimos-space.com>
> Good news! Which version of GDAL/PostGIS are you using? I commited a
> new version of the GDAL driver on October, and included WKT Raster as
> official part of PostGIS on September 26th.
> On Mon, Nov 29, 2010 at 9:40 PM, Maurício de Paulo
> <mauricio.dev at gmail.com> wrote:
> > Ok, after a few minutes of implementation here it is. Now the plugin
> lists
> > the tables from the database and shows some of it's metadata. Now I think
> > it's fully functional. If anyone finds a bug , please tell me.
> > Best regards,
> > On Mon, Nov 29, 2010 at 3:50 PM, Maurício de Paulo <
> > wrote:
> >> Hi Jorge,
> >> Good news. The plugin wktraster is exactly a tool to connect qgis to
> >> postgis rasters through GDAL and visualize the data.
> >> Stefan asked about the processing. This is something the plugin doesn't
> >> do.
> >> I've tested with a friend both qgis (with the plugin) and mapserver
> >> loading postgis rasters. Both worked fine, and the only requirement is
> qgis
> >> compiled against gdal 1.7.
> >> I'm interested in updating the plugin this week to work as I've planned.
> >> It's going to speak for itself.
> >> Best Regards,
> >> Mauricio
> >> Ps.: Anyone willing to help and join this effort is always welcome.
> >> On Mon, Nov 29, 2010 at 3:45 PM, Jorge Arévalo
> >> <jorge.arevalo at deimos-space.com> wrote:
> >>> Hi,
> >>> If you want a GDAL version compiled with PostGIS Raster support on
> >>> Windows, you may take a look here: http://vbkto.dyndns.org:1280/sdk/
> >>> Visualizing PostGIS Raster data via GDAL driver is one of my TODO
> >>> tasks. I don't have too much free time now, but if you're interested
> >>> on this topic, and you're going to test it, please let me know. There
> >>> are more people interested on that, and I'm providing support to some
> >>> of them (not as much support as I'd like, because the time...)
> >>> Best regards,
> >>> Jorge Arévalo
> >>> Internet & Mobilty Division, DEIMOS
> >>> http://mobility.grupodeimos.com/
> >>> http://gis4free.wordpress.com
> >>> 2010/11/29 Stefan Keller <sfkeller at gmail.com>:
> >>> > Ok (I'm cross posting to qgis-developer and postgis-users).
> >>> > I'm still not sure if I did express myself clearly:
> >>> > You say, that under Windows, there's no QGIS compiled against GDAL
> >>> > 1.7/1.8 with PostGIS Raster support?
> >>> > What I finally dream of, is using QGIS to display the results of a
> SQL
> >>> > query (either as raster or vector) against at least one raster layer.
> >>> > This query contains raster constructors (like ST_Intersection) and
> >>> > operations (like ST_Reclass; see
> >>> > http://trac.osgeo.org/postgis/wiki/WKTRaster).
> >>> > Any suggestions?
> >>> > -S.
> >>> > 2010/11/29 Maurício de Paulo <... at gmail.com>:
> >>> >> Hi Stefan,
> >>> >> WKTRaster Plugin just repasses the right information to the GDAL
> >>> >> driver.
> >>> >> It's not a new qgis driver.
> >>> >> I'm planning on implementing the table listing using pyqt this week.
> I
> >>> >> was a
> >>> >> little delayed by my master's application.
> >>> >> The idea in the plugin is simply find the QGIS's conections
> available,
> >>> >> list
> >>> >> the raster tables inside postgis and pass the right arguments to the
> >>> >> gdal
> >>> >> driver.
> >>> >> At the moment I haven't found any gdal 1.7 windows build with QGIS.
> >>> >> GDAL 1.7
> >>> >> introduces wktraster. The driver conects to postgis raster and read
> it
> >>> >> as a
> >>> >> binary. It's still VERY unstable and gdal version 1.8 seems to be
> >>> >> greatly
> >>> >> improved.
> >>> >> So what a windows user need to get the plugin to work is a (still
> not
> >>> >> found)
> >>> >> qgis compiled against gdal 1.7.
> >>> >> You can compile your's from source if needed.
> >>> >> So, as far as qgis to wktraster, with the plugin qgis reads the
> >>> >> wktraster as
> >>> >> a regular raster. Just for show. If you did some kind of processing
> >>> >> and
> >>> >> populated a new raster table, qgis is going to read that result too.
> >>> >> The
> >>> >> plugin is not intended (at the moment at least) to raster processing
> >>> >> inside
> >>> >> postgis. It just loads the table to the screen.
> >>> >> In the future, with a more stable wktraster probably someone (or me)
> >>> >> is
> >>> >> going to write a set of wktraster's tools as a plugin, but for the
> >>> >> moment it
> >>> >> should be run as sql. I advise postgis manager's to the task.
> >>> >> Best regards,
> >>> >> 2010/11/29 Stefan Keller <... at gmail.com>
> >>> >>> Hi,
> >>> >>> There are new versions around of "PostGIS Raster"
> >>> >>> (renamed from formerly known "PostGIS WKT Raster").
> >>> >>> What's the status of your "WKTRaster Plugin 0.1"?
> >>> >>> I assume it's rendering the raster values (e.g. from ST_AsBinary) -
> >>> >>> not the polygons/geomvals (from ST_DumpAsPolygons), right?
> >>> >>> Is there a chance to get it running on Windows too?
> >>> >>> Are there other plugins?
> >>> >>> Yours, S.
> >>> > _______________________________________________
> >>> > postgis-users mailing list
> >>> > postgis-users at postgis.refractions.net
> >>> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> >> Mauricio de Paulo
> >> Engenheiro Cartografo
> > Mauricio de Paulo
> Jorge Arévalo
Mauricio de Paulo
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101129/04fafca6/attachment.html>
