[postgis-users] Query to select dangling line segments
Kevin Neufeld kneufeld.ca at gmail.com
Tue Nov 30 00:14:29 PST 2010
On 11/29/2010 2:16 PM, Brian Stempin wrote:
>     Is your dataset fully noded (where the only intersection between
>     geometries occur at the endpoints)?
> There are places where segments run through endpoints and segments run
> through other segments.
Ah.  Then in that case the GROUP BY approach won't work for you.  I used
it quite successfully over a large fully-noded stream network I used to
work on where I needed to look for locations of interest (head waters,
degree-2 nodes, confluences of 3 streams coming together, etc).
So for you, what if you reversed the logic of your query?  Do a
self-join as you specified, but look for the ids that intersect and then
negate it.
ie.
-- list all ids where the startpoint doesn't intersect
SELECT osm_id
FROM "OSMData".osm_mn_data_highway_20101129_101234 t1
WHERE osm_id NOT IN (
    -- list all ids where the startpoint intersects something.
    SELECT t1.osm_id
    FROM "OSMData".osm_mn_data_highway_20101129_101234 t1,
    "OSMData".osm_mn_data_highway_20101129_101234 t2
    WHERE t1.osm_id <> t2.osm_id
    AND ST_Intersects(ST_StartPoint(t1.way), t2.way)
-- do the same for endpoints.
Alternatively, you should get similar results by doing a LEFT JOIN and
filter all cases that don't match.
-- This is of course untested, but here's the idea
SELECT t1.osm_id
    LEFT JOIN "OSMData".osm_mn_data_highway_20101129_101234 t2
       ON (t1.osm_id <> t2.osm_id AND
           ST_Intersects(ST_StartPoint(t1.way), t2.way))
WHERE t2.osm_id IS NULL;
Cheers,
Kevin
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101130/d9f6ed4b/attachment.html>
