[postgis-users] pl/pgsql getting ST_X output as REAL
Jan Saalbach fire at dubmosphere.de
Tue Oct 5 07:12:29 PDT 2010
Hi all,
on my journey to learning PostgreSQL and PostGis I am now trying to
write a function in pl/pgsql. In this little program I would like to
determine the frequency of different x-values of POINT3D objects to
get an idea about how many "rows" were digitized.
Therefore I would like to use the following command:
FOR x_value IN SELECT ST_X(points) FROM table LOOP
The problem is that in the DECLARE-section x_value has to be set to
type RECORD.
x_value RECORD;
In the course of the program I would like to work with REAL values for
convenience. How do I go about casting the x_value RECORD, which seems
to be some kind of string with brackets around the value, to a REAL
object? Any ideas?
Regards
Jan
