[postgis-users] pgsql2shp
Bob Pawley
rjpawley at shaw.ca
Mon Oct 11 15:26:17 PDT 2010
The reason I asked is that I had tyo upgrade pgdump in order to get it to
work.
I'm using this (and variations of it)
pgsql2shp -f c:\user\bob\ShapeTest.shp -h localhost -u postgres -P
London2342 PDW
"Select the_geom from p_id.image where p_id_id = '1534'"
or
pgsql2shp -f myfile.shp -h localhost -u postgres -P London2342 PDW
p_id.image -g the_geom
The message just tells me that "No prj file will be generated".
I am using 8.4 if that helps.
Bob
Sent: Monday, October 11, 2010 1:30 PM
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Subject: Re: [postgis-users] pgsql2shp
> As far as I know, all versions of pgsql2shp work just fine on Win7,
> and they should do exactly what they are documented to do for the
> situation you describe. What exactly are your problems? If the command
> had an error and didn't produce any files, what did you type?
> -Mike
> On 10 October 2010 14:03, Bob Pawley <rjpawley at shaw.ca> wrote:
>> I'm still having problems.
>> My pgsql2shp version is -
>> RCSID: $Id: pgsql2shp.c 4914 2009-11-27 18:12:43Z pramsey $ RELEASE: 1.4
>> Is this the right version to be using on Win 7??
>> Bob
>> From: "Stephen Woodbridge" <woodbri at swoodbridge.com>
>> Sent: Sunday, October 10, 2010 11:14 AM
>> To: <postgis-users at postgis.refractions.net>
>>> On 10/10/2010 1:52 PM, Bob Pawley wrote:
>>>> Hi
>>>> I am using the following
>>>> pgsql2shp -f Test.shp -u postgres -P London2342 -k PDW p_id.image -g
>>>> the_geom
>>>> to export a shape file from postgis.
>>>> Even tho I specify a single geometry column to be exported I get
>>>> warnings that column names have been truncated.
>>> DBF files can only have a maximum of 11 character column names. You
>>> probably have some that are longer. You can work around this problem by
>>> using a query at the end of the commandline like:
>>> 'select col1, col2, col3whichisverylong as col3, ... the_geom from
>>> p_id.image'
>>>> Command prompt also informs me that "No prj file will be generated"
>>>> Also a warning 'cannot determine spatial reference". I thought the
>>>> default was -1?
>>> -1 is the default and it means that you have not defined a projection so
>>> it can not create a .prj file. It is generally a good idea to always
>>> define
>>> a projection for your data.
>>> -Steve W
>>>> I also get messages-
>>>> "Done (postgis major version: 1)
>>>> Output shape: Polyline
>>>> Dumping: xx [8 rows]"
>>>> What am I doing wrong???
>>>> Bob
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
