[postgis-users] How to insert polygon
Puthick Hok hputhick at gmail.com
Tue Oct 12 16:35:50 PDT 2010
I started using Postgis a couple months ago. Now I have a problem
inserting a polygon. The table definition is like this.
Table "public.siteloc"
    Column    |  Type   | Modifiers
 siteid       | integer | not null
 sitelocation | polygon | not null
Indexes:
    "siteloc_pkey" PRIMARY KEY, btree (siteid)
    "sitelocation_sp_index" gist (sitelocation)
When I ran the following SQL statement:
INSERT INTO siteloc (siteid, sitelocation) VALUES (18,
ST_GeomFromText('POLYGON((0 0, 4 0, 4 4, 0 4, 0 0))', -1));
I got this error:
ERROR:  column "sitelocation" is of type polygon but expression is of
type geometry
LINE 1: INSERT INTO siteloc (siteid, sitelocation) VALUES (18, ST_Ge...
HINT:  You will need to rewrite or cast the expression.
When I tried to cast it with this statement:
INSERT INTO siteloc (siteid, sitelocation) VALUES (18, CAST(
ST_GeomFromText('POLYGON((0 0, 4 0, 4 4, 0 4, 0 0))', -1) AS polygon) );
or
ST_GeomFromText('POLYGON((0 0, 4 0, 4 4, 0 4, 0 0))', -1)::polygon);
I got this error:
ERROR:  cannot cast type geometry to polygon
LINE 1: ...romText('POLYGON((0 0, 4 0, 4 4, 0 4, 0 0))', -1)::polygon);
I tried google, it did not help. Is there a problem defining my field
'sitelocation' as 'polygon' rather 'geometry'.
Please help me.
Puthick
