[postgis-users] create xml file from sql table
zhang zhe luckyclare at hotmail.com
Tue Oct 19 06:05:44 PDT 2010
hello,
I tried your code
psql -At -U postgres -c “select table_to_xml(‘building3’,true,true,’’);” postgres > query.xml
but it gives erro
ident authentication failed for user "postgres"
what should be the user name. I tried with localhost, it gives the same error.
Do you have any idea?
Thanks
Date: Tue, 19 Oct 2010 21:54:11 +1000
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] create xml file from sql table
You can use psql to run your query from the command line.
psql -At -U {username} -c “select table_to_xml(‘building3’,true,true,’’);” {database} > query.xml
-A unaligned output (no formatting of results for display purposes)
-t Rows only (ie no header, so your xml file to only has xml in it)
If you don’t really need an automated way you can use the “Execute query to file” option in pgAdmin.
Regards,
Josh
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of zhang zhe
Sent: Tuesday, 19 October 2010 9:37 PM
Subject: [postgis-users] create xml file from sql table
Hello,
Does anyone knows how to generate xml file from postgres table.
will print xml file in data output . How can I generate a file, and save it to directory automatically. I want to write this function in php code.
Thank you very much.
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
_______________________________________________ postgis-users mailing list postgis-users at postgis.refractions.net http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101019/a4ee858e/attachment.html>
