[postgis-users] PostGIS 1.5.2 make check fails
Lee Hughes
hughesl at science.oregonstate.edu
Tue Oct 19 12:59:21 PDT 2010
Running "make check" as root with PGUSER=postgres results in:
could not access file
"/usr/local/src/postgis-1.5.2/regress/00-regress-install/lib/postgis-1.5":
Permission denied
in /tmp/pgis_reg_27083/regress_log
I'm running this as root, and the /usr/local/src/postgis-1.5.2
directory tree is owned by root, so there should be no file permission
issues. The directory
usr/local/src/postgis-1.5.2/regress/00-regress-install/lib does exist.
Any ideas?
Thanks-
Lee
