[postgis-users] issue while building postgis-1.5.2 with pg-9
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Thu Oct 21 04:03:03 PDT 2010
Dharmendra Goyal wrote:
> Hi,
> I am trying to build postgis-1.5.2 with postgresql-9.0.1 and i am
> getting following error while building the sources:
> c:/pginstaller.pune-repo/proj-4.6.1.staging/lib/proj.lib(pj_utils.obj):(.text+0x47):
> undefined reference to `__security_cookie'
> c:/pginstaller.pune-repo/proj-4.6.1.staging/lib/proj.lib(pj_utils.obj):(.text+0x539):
> undefined reference to `@__security_check_cookie at 4'
> Error is coming just after executing:
> make[1]: Entering directory
> `/c/pginstaller.pune-repo/postgis.windows/postgis'
> dllwrap -o postgis-1.5.dll --dllname postgis-1.5.dll --def
> libpostgis-1.5dll.def lwgeom_pg.o lwgeom_debug.o lwgeom_accum.o
> lwgeom_spheroid.o lwgeom_ogc.o lwgeom_functions_analytic.o
> lwgeom_inout.o lwgeom_estimate.o lwgeom_functions_basic.o lwgeom_gist.o
> lwgeom_btree.o lwgeom_transform.o lwgeom_box.o lwgeom_box3d.o
> lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_geos.o lwgeom_geos_prepared.o
> lwgeom_export.o lwgeom_svg.o lwgeom_gml.o lwgeom_kml.o lwgeom_geojson.o
> lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_triggers.o lwgeom_dump.o
> lwgeom_functions_lrs.o long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o
> geography_inout.o geography_gist.o geography_btree.o
> geography_estimate.o geography_measurement.o
> -Lc:/PGINST~1.PUN/PGSQL-~1.1/lib -Wl,--allow-multiple-definition
> -L/C/pgBuild/krb5/lib/i386 -L/C/pgBuild/OpenSSL/lib
> -L/C/pgBuild/zlib/lib -Wl,--as-needed
> -L/C/pginstaller.pune-repo/geos-3.1.1.staging/lib
> -L/C/pginstaller.pune-repo/proj-4.6.1.staging/lib -lgeos_c -lproj
> -L/c/pgBuild/libxml2_mingw/lib -lxml2 -lws2_32 ../liblwgeom/liblwgeom.a
> -Lc:/PGINST~1.PUN/PGSQL-~1.1/lib -lpostgres
Looks like an MSVC-specific issue with the PROJ.4 library to me:
http://blogs.msdn.com/b/nikolad/archive/2005/01/27/unresolved-external-security-cookie-with-platform-sdk-compiler.aspx
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
