[postgis-users] Measure distance to nearest border
Andreas Forø Tollefsen
andreasft at gmail.com
Fri Oct 22 00:01:27 PDT 2010
Thanks. Solved!
That worked like a charm.
Exactly what i wanted.
Andreas
2010/10/21 Nicklas Avén <nicklas.aven at jordogskog.no>
> Ok
> still don't get the second query. If I understand you right you could try
> this:
> CREATE TABLE borddisttest2 AS
> select a.gid, a.cell, MIN(ST_Distance(a.centroid, b.the_geom)) AS distance
> FROM pgfinal2008 a, cshapes b, cshapes c WHERE a.gwcode != b.gwcode AND
> b.gwsyear <= 2008 AND b.gweyear >= 2008 and a.gwcode = c.gwcode and
> st_intersects(b.the_geom, c.the_geom)
> GROUP BY a.gid LIMIT 1;
> Here I assume that every country only have one representation in cshape.
> What I do is that I try to only get the countries that intersects with the
> country that has the same gwcode as the cell you are calculating.
> Here it is essential to have spatial index on the country-polygons and the
> centriod-point
> You should also have index on gwsyear, gweyear and gwcode in both
> pgfinal2008 and cshapes.
> I guess your limit 1 is just for testing purposes
> Probably you could make it quite a lot faster if you could trick it to inly
> do the intersection process once per country and not once per cell.
> Right now I don't see any good way to do that. Hopefully someone else sees
> a solution to that, or I will return if it comes to me.
> But maybe, if I recall right there were some discussions here that
> postgresql can cache results from one row to another. If soo it should work
> by itself or at least if you order your query by the gwcode so it takes all
> grid cells from one country first.
> /Nicklas
> 2010-10-21 Andreas Forø Tollefsen wrote:
> Ok. I will try to explain more in detail.>
> I have a vector grid consisting of 64818 grid cells. Each of these cells
> are stored in the pgfinal2008 table, with two geometries variables: centroid
> (point) and cell (polygon).
> Each grid cell have a gwcode variable which is the country code.
> In addition i have a table with all countries represented by polygons, and
> a table with all countries represented by their boundaries (line).
> What i want to do is to measure the distance from each cell to the closest
> border..
> While a simple measure of ST_Distance(pgfinal2008.centroid,
> cshapes.the_geom) WHERE pgfinal2008.gwcode != cshapes.gwcode will measure
> the distances, it will measure to all the polygons where the gwcode is
> different.
> However, I can apply a MIN() function to select the nearest of these,
> though this will take considerable time since every cell need to be measured
> to every country.
> What i need to solve is how to limit the distance to measuring only to
> neighbouring countries of the country the cell is located.
> Thanks for your help Nicklas.
> hmm, I have to admit I don't really understand what you are trying to do,
> but there are some thingsI don't think you really mean.
> select a.gid, MIN(ST_Distance(a.centroid, b.the_geom)) AS distance FROM
> pgfinal2008 a, cshapes b, cshapes c WHERE a.gwcode != b.gwcode AND b.gwsyear
> <= 2008 AND b.gweyear >= 2008 GROUP BY a.gid LIMIT 1;
> > Why do you have, cshapes c, there. if you have 200 countries in it taking
> away that will reduce the querytime to 1/200
> What you get here is theclosest country from your first grid cell.
> SELECT pgfinal2008.cell, borddisttest2.gid, MIN(borddisttest2.distance)
> FROM borddisttest2, pgfinal2008 WHERE borddisttest2.gid = pgfinal2008.gid
> GROUP BY pgfinal2008.cell, borddisttest2.gid;
> This I don't get. Do you have many rows in pgfinal2008 with the same value
> in pgfinal2008.cell but different pgfinal2008.gid. What is "cell"?
> /Nicklas
> > Thanks.>
> I have found a way to do this calculation.
> However, since i gave 64818 cells and almost 200 countries, the distance
> from every cell to every country is calculated before the minimum distance
> is selected.
> This takes awful lot of time.
> Any ideas on how to increase the performance?
> DROP TABLE IF EXISTS borddisttest2;
> DROP TABLE IF EXISTS borddist2008;
> CREATE TABLE borddist2008 AS
> 2010/10/13 Nicklas Avén <nicklas.aven at jordogskog.no>
> Hi
> You can not cast to geography that way (if I haven't missed something
> essential)
> > > And if you could you would mix geometry and geograph type in
> ST_Distance, which wouldn't work.
> St_Distance for geometry vs geography uses totally differnt algorithms. The
> geography calculations is far more advanced.
> ST_Shortestline only works for geometry type.
> /Nicklas
> > > 2010-10-13 Andreas Forø Tollefsen wrote:
> > > Hi>
> Thanks,
> I will give it a try.
> The reason I used the geography types in the distance query, were to get
> the distance in meters instead of degrees.
> Andreas
> Hi
> As I understand you you want to get the distance from each cell to the
> closest neighbour country. Then, why don't you just query the distance from
> your cell to closest country with other gwcode?
> Maybe something like:
> Create table borddisttest as
> Select ST_Distance(st_collect(b.the_geom), c.centroid)
> from cshapes a, cshapes b, pgfinal2008 c
> where a.gwcode=c.gwcode and b.gwcode != c.gwcode and
> st_intersects(a.the_geom, b.the_geom)
> group by c.gwcode and c.the_geom;
> With some tweaking like ordering the cells by gwcode I don't think the
> intersection calculation have to be done for each cell. Otherwise this is a
> very bad approach if there are many grid-cells.
> indexing on gwcode on both tables and spatial index on the country geoms
> for the intersection will also be of importance.
> I don't understand:
> geography(pgfinal2008.centroid)
> what does geography means here?
> I would also go for calculating the centroids on the fly. It should be fast
> and you will not get the trouble of updating the centroid column if
> adjustuing the grid.
> About doing calculations comparing geometries inside a dataset you use self
> join.
> You can join a table with itself as long as you put an alias so you can
> identify them like I did above with a, b and c
> Well, I am not sure I answered the right question but anyway...
> HTH
> Nicklas
> Hi all,
> I have two datasets. On is a quadrate grid, and the other is the boundaries
> of all countries.
> What i want to do is to measure the distance from each centroid of the grid
> cells to the nearest border, but not all borders. Only the international.
> First i convert my country polygon dataset into line features:
> select gwcode, gwsyear, gweyear, ST_Boundary(the_geom) AS line Into
> cshapes_line from cshapes;
> Next i calculate the distance from the centroid of each cell to the nearest
> border where the gwcode (country code) of the cell is the same as the gwcode
> in the line feature.
> drop table if exists borddisttest;
> select pgfinal2008.cell, pgfinal2008.gwcode,
> ST_ShortestLine(pgfinal2008.centroid, st_boundary(cshapes.the_geom))
> AS shortestline, ST_Distance(geography(pgfinal2008.centroid),
> st_boundary(cshapes.the_geom))/1000 AS borddist
> into borddisttest
> from cshapes, pgfinal2008
> where cshapes.gwcode = pgfinal2008.gwcode;
> The problem here is that when using ST_Boundary, it converts all boundaries
> into lines, while i only want to get the boundaries where two polygons with
> different gwcodes meet.
> The lines where two countries meet are overlapping, meaning these borders
> have two gwcodes but in different line entries.
> Is there a way to calculate the overlaps within one dataset? If i could do
> this, then i could put a clause so the measurement only measures to lines
> with 2 or more gwcodes.
> Thanks.
> > > >_______________________________________________
> > > > postgis-users mailing list
> > > >postgis-users at postgis.refractions.net
> >postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20101022/21acf6c0/attachment.html>
